TWIN motor SV27
  • Avanti
    • 1280
    #31
    side shot for RCprince
    esc wired up
    The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
    • RCprince
      • Jul 2007
      • 1637
      #32
      Cool, you might wanna try the Nitro SV props composites x437 I think they may be small enough for those motors, they come 2 to a pack
      Samuel Johnson - “An injustice anywhere is an injustice everywhere.” William Cooper "listen to everything, read everything, and believe nothing unless you can prove it in your own research!"
      • Avanti
        • 1280
        #33
        the boat ran pretty good I can't wait to get some brushless power in her
        • hex-dj
          • 238
          #34
          Nice! Seems to be running well. If you get those brushless I d like to know something. I will like to do a similar project ,but with a different boat some day. How do you put two brushless ESCs to run with only one reciever or perhaps a DSM reciever?
          • Avanti
            • 1280
            #35
            I'm thinking one hydra 240 should do the trick
            or two smaller controllers and tie the receiver wires together
            (I have not thought it all the way through yet, but I know it is possible)
            the next step for me is a counter rotating shaft for one side.
            the props ride half out of the water like a true surface piercing setup.
            I also loved the way it sounded.
            my guess is it ran around 30mph with 12cell 3300nimhs.
            all my homemade parts held nicely too.
              • 7277
              #36
              One brushless controller and 2 motors will not work, you will need 2 controllers with the reciever leads wired together.
              • hex-dj
                • 238
                #37
                Thanks for the info Doby. I guess that a separate reciver batt. is needed right?
                • obrien
                  • 1264
                  #38
                  Doby you don't think you could use a hydra 240 to run twins since it has two sets of wire leads coming out of it?
                  • lonewolf
                    • Jul 2007
                    • 658
                    #39
                    the double wires are for handleing the current.. With brushless to need an esc for each motor, and run a "y" cable from esc's to rx.
                    • Avanti
                      • 1280
                      #40
                      Thanks for the info Doby & Lonewolf
                      • RCprince
                        • Jul 2007
                        • 1637
                        #41
                        • obrien
                          • 1264
                          #42
                          thanks for the info guys. It is good to know that I was wrong on that. I would have felt bad if Avanti had bought one controller and killed it.
                          • Avanti
                            • 1280
                            #43
                            Well this boat will be shelved for now as I am building a DF33 keep an eye on this thread in the fall
                            • Brushless01
                              • Apr 2010
                              • 487
                              #44
                              You put the motor mount in the wrong way round !!
                              Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
                              • Avanti
                                • 1280
                                #45
                                the mount was reversed so the twin motors would fit
