Rio ep scratch build
  • Killah2469
    • Oct 2012
    • 114
    Stuffing tube broke on Rio ep so I decided to gut the boat and start from scratch.
    Here is the boat before I started.
    Also I forgot to mention this is my first build.
    Check out my youtube channel
  • Killah2469
    • Oct 2012
    • 114
    I've started by gutting the hull.
    Now I've laid fiberglass in the back part of the boat. I'm gonna glass the whole inside of the hull and and reinforce the transom
    with a piece of aluminum.
      [ATTACH=CONFIG]101207[/ATTACH]
      [ATTACH=CONFIG]101208[/ATTACH]
      Looks good, what did you use to adhere the FG to the ABS hull? I thought epoxy doesn't really work with ABS, read somewhere that Randy at BBY use CA to glass down the cloth. Not trying to distract you, I admire what you are doing, and I will be the first to say that I will be glad that I am wrong on this.
        Ah, I see you have your thinking cap on grass hopper.
        You just need sand the abs good and than clean it with soap and water and dry it good,
        Than apply a layer of methylene chloride acrylic cement to the ABS and fiberglass and quickly stick the two together.
        Read more: http://www.ehow.com/how_7537189_glue...#ixzz2XHP8uJBz
          Lenny,
          Thanks, I am sorry to the OP for yanking this thread a bit, but I guess it's a good thing to keep in mind.
          That Rio is going to be really good after the rebuild!
            Hey,
            I am sure he is cool with any input.
            You have a modded Rio and help him when he was just brushed,
            And I gave him a monster to learn how to drive and setup.
            • Killah2469
              • Oct 2012
              • 114
              I got the stuff from my LHS i'll take a pic of it so you can see what I'm using.
              • egneg
                • 4759
                You just need sand the abs good and than clean it with soup and water and dry it good,
                Chicken noodle or tomato?
                IMPBA 20481S D-12
                • Killah2469
                  • Oct 2012
                  • 114
                  This is the epoxy I am using.
                  • Killah2469
                    • Oct 2012
                    • 114
                    Well I got to work on the Rio today and I got the whole boat glassed and I also reinforced thr transom with aluminum.
                    Here are some pics inside the boat.
                    This is the transom plate
                    • Killah2469
                      • Oct 2012
                      • 114
                      I also have the rudder, trim tabs and my new stuffing tube with Teflon liner. I still need to figure out turn fins but I think Ill make them from some aluminum
                      I have left.
                        Tomato with the acids.
                          The 30 min. Epoxy is a good choice, the longer the cure time the stronger the bond usually. Perhaps my concern for the epoxy-ABS bond was unnecessary.
                          Cheers!
                          • Killah2469
                            • Oct 2012
                            • 114
                            ya I just sanded the hull and laid the glass it bonded great.
                            I find that it doesn't last 30 min it only stays workable for about 15 min
                            so if you can find something that is longer cure time I would get that.
                            • J.W. Pepper
                              Here's Mine
                              Here's how I did mine...
                              PB 1800Kv motor from IM-31(v1) with SK-90A speedo, modded Octura coupler - went from 5mm motor ->.150" Flex to 5mm motor ->.130" flex (didn't want to spend $5 shipping for just a coupler), running on 3S LiPo, Tactic TTX-240 Tx with TR-624 Rx for improved reception. I shortened the servo tray couple years ago, so there's plenty of room for just about any Rx on the market.
                              Kintec x442 aluminum prop prepped & sharpened by me - don't have pix.
                              Rudders cut down to 2.5" OAL (see attached comparison pic), took out that God aweful twichyness these boats are famous for & reduced drag at same time. With D/R set to full, the boat handled beautifully - on 8.4v humps, I started with them to break in the new motor & test the new setup.
                              After the break in, I pulled 'er in & programmed the ESC for LiPo's, installed the 3S pack and sent 'er back out, went slow at first to see how she would do. After diddle daddling around for a few minutes I decided to see what see could do.
                              Got 'er going up to bout 1/2 throttle, then pegged it... that boat took off like a rocket ship on meth, Jezus I didn't a Rio could go that fast - I just wish somebody would have been there with a camcorder to film it, A to B like a lighting bolt. If that was any kind of preview of what IM-31's can do normally, then I can't wait to mine finished up & in the water.
                              I had my hands full of steering wheel & throttle just trying to keep her upright Unfortunately I got too brave & she flipped after bout 5-mins & drifted out to the middle of the lake. Once again the R/C boat gods were looking after me because some people rescued her for me.
                              Once I got 'er back, I replaced the Kintec prop with a Venom x436/3 per Lenny's suggestion. Definitely solved the torque roll issue, but also killed top end speed. It's like.. the boat would get going, then blaaa.. ever see how a gas powered engine acts when the governor kicks in?? That's precisely how my Rio was acting.
                              Couple days later I removed the PB motor & SK speedo and went back to last years motor/ESC setup with upgraded motor cooling - hopefully that will keep it running cool, it's been an issue ever since I went to BL.
                              Enjoy the pix.
