(retry)my brushless super hawaii project..
  • eclipse
    • 365
    #46
    the fins are half way in the water with 2 bateries
    just a kid with a super hawaii project
    • eboat
      • 726
      #47
      But once the boat gets moving it will not be sitting as deep in the water
      • eclipse
        • 365
        #48
        i no that it will be the same as the pic now .how do you like the hardware??
        • eboat
          • 726
          #49
          Looks good so far
          You are going to need a long stand off to get the rudder back by the prop
          What size is the prop you have on it ?
          Did you ever decide on what motor you are going to use
          • eclipse
            • 365
            #50
            stand off is going to be 3 inches to the center of rudder
            i have a octura x640 on it
            im getting the kb one the one you suggested thanks
            is that 200amp esc good becouse i might get the same one as you?
            • eclipse
              • 365
              #51
              the things i sill need to get::
              rudder
              kb 8turn xl bl motor
              himodels 200 amp esc
              batteries
              wow 4 more thing and im ready to run
              • eclipse
                • 365
                #52
                edited
                locktite 603 http://www.offshoreelectrics.com/pro...prod=mc-loc603 got
                speedmaster stinger 3/16 http://www.offshoreelectrics.com/pro...os-stinger-str got
                Octura.150 flex shaft unasembled http://www.offshoreelectrics.com/pro...oct-oc150L-24c got
                brass bullet nut octura 3/16 http://www.offshoreelectrics.com/pro...od=oct-oc6pnmmgot
                coupler http://www.offshoreelectrics.com/pro...rod=ose-str-ci got
                brass tube http://www.offshoreelectrics.com/pro...dh-ks-brass-tb got
                grimracer grease http://www.offshoreelectrics.com/pro...od=dh-aqub9500 got
                2 ep 4500 7cell stick packs http://www.offshoreelectrics.com/pro...d=ep4500-7cell
                kb BL motor 8 turn with water jacket http://www.offshoreelectrics.com/pro...php?prod=kb-45
                himodel 200 amp esc http://www.himodel.com/electric/HiMo...200A-OPTO.html
                Some kind of rudder
                A variety of props to test
                • eboat
                  • 726
                  #53
                  So the costs are starting to add up but the end is in sight
                  Battery $45 X 2 $90
                  Motor with cooling $85
                  ESC $65
                  Rudder $40 to $50
                  Shipping stuff $25
                  Total $315
                  • eclipse
                    • 365
                    #54
                    lol batteries are actually gona be 60 total becouse i changed my mind im going to make my own pacs
                    ruddder is gona be around 55
                    total of 235$
                    • eclipse
                      • 365
                      #55
                      im getting this rudder with 6 inch set back to put it right behing the stinger http://www.offshoreelectrics.com/pro...ros-rud-dualpu
                      what do you guys think
                      • Avanti
                        • 1298
                        #56
                        you might just go with a side rudder set up since you are single prop. (like most other boats out there) (of course there is something to be said for being different)
                        that is a sweet stinger I would love to get my hands on a couple of those.
                        good luck, I can't wait to hear how it runs.
                        The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                        • eclipse
                          • 365
                          #57
                          im gonna be different and mount the prop behind the stinger.
                          lol i just got stabed with that bullet nut i bought lol
                          thanks
                          • eclipse
                            • 365
                            #58
                            ok im thinking going lipo!!!!!!!!!what lipo do yall recomend ???
                            • Quicksilver
                              • 226
                              #59
                              cant help you with lipos, but the boats looks great!.....besides those turn fins. The bottom screw hole fo the fins should be where the outside screw hole for the trim tabs. In fact I would utilize the hole for the trim tabs and use it for the bottom screw/bolt of the fin. Wont look really good, but it'll look like you know what you're doing. With the fins where they are now, once you're on plane, they'll be completely out of the water.
                              Again nice job though, hardware and install look good so far.
                              BOATS CAN FLY AND SHOULD!
                              • ace028
                                • 986
                                #60
                                I agree, your turn fins are too high, you need to move them down or get longer ones, once your boat is on plane, they probably wont even touch the water, and will be useless.
                                Twin power =
