help with 40" project
  • cheesewizz69
    • 3
    to start out, plain and simple. i know NOTHING about electric boats. i currently have a 60" gasoline powered deep vee. looking for a new project i thre nitro out because of the price of gas so i looked over to electric. moving on to the project.
    i have a spare 40" prather hull, its quite heavy but a reasonable wieght. i have been looking around the forum and youtube for setups on this size boat but to be blunt, everyone is running the supervee's. i've been considering a Feigao 8xl or 9xl motor. i'm not building this boat for competition and not looking for speeds over 40mph. i want this boat to have something to toy around with while my big boat is cooling off, and for a change of pace. any suggestions on motor, esc, and battery combos i should use?
  • ReddyWatts
    • 1700
    KB45 11XL on 6S lipo or 18 NiMH, X645 prop, 120 amp controller.
    Over 20,000 rpm at 70 amps. Mid 30's.
    Water cool everything.
    ReddyWatts fleet photo
    • blastoff
      • Apr 2008
      • 155
      Is there drive hardware ??? Is there any way you would do dual motors, for a change of pace ???
      • ReddyWatts
        • 1700
        Dual motors/props would be ok in a cat hull.
        • blastoff
          • Apr 2008
          • 155
          Unless you choose dual outdrives
          Mmmmmmmm Outdrives
          • ReddyWatts
            • 1700
            Start a build thread and GO for it!
            • Flyguy55
              • 216
              Its a Deep Vee , I don't remember Prather ever making a cat hull.I ran a big ( maybe 48" )Prather hull with 2 Rossi 65s , It was fun .
              • ReddyWatts
                • 1700
                My suggestion to "Cheezewizz69", with the a large prather hull is:
                My suggestion to "blastoff" is go for a dual outdrive, if he wants to be creative.
                • blastoff
                  • Apr 2008
                  • 155
                  Duals Rule (just my opinion) Here are two of my Dual's
                  Cheers
                  • cheesewizz69
                    • 3
                    when i bought the hull it was set up for nitro and already has a shaft for the flex cable molded into the hole, i was hoping i could just utilize it and not have to start cutting it up. so i dont think i'll be doing dual just yet also, remember this is my first electric build, EVER, so i dont want to get complicated with anything.
                    and between lipo and NiMH, which will give me a longer run time.
                    • ReddyWatts
                      • 1700
                      You compare the "mah" rating of the battery. This is what determines the runtime. It is the same for a NiMH or lipo.
                      To calculate run times
                      Battery Mah rating (times) 0.06 (divided by) motor load in amps = run time
                      Example: 5000 MAH (X) .06 (divided by) 70 amps = 4.25 minutes of run time (times) 80% = 3.4 minutes
                      Should not run your batteries down more than 80%.
                      • skidooguymxz550
                        • Jun 2007
                        • 242
                        blast off twins do rule!
                        the one with twins is the big boat
                        cheeze!! i love those old prather hulls so do her justice, the remind me of old scarab ninjas
                        • blastoff
                          • Apr 2008
                          • 155
                          I think that's why we stare at females with low cut tops !!!!
                          • cheesewizz69
                            • 3
                            i am NOT doing twins
                            • Flying Scotsman
                              Fast Electric Adict!
                              • Jun 2007
                              • 5190
                              Skidooguy, what motors, batteries, esc's are you going to run and what is the length and bare weight of that hull. I would personally run a single powerscheme on a V hull. Cheesewizz69 follow ReddyWatts suggestions
                              Douggie
