scat dat 32 lipo
  • stephenszj
    Junior member
    • 5
    scat dat 32 lipo
    I have a scat cat 32 by bby. It has the older hydro 240, neu 1521 1.5d. I have been running 18 4200in this with a octura x 445. It only reaches 130 after 3 min runs. batteries get to 175. Thats way to hot. My question is what kind of lipo can I run? My understanding is the hydro 240 cant handle a 6 s. I think a 5s around 4000 would work fine. Has anyone run a simaliar set up? What kind of speed gains can I expect with a 5s around 4000 with a max amp draw of 240. What kind of lipo? how big? how many cells? 1 or 2 lipo? will lipos let me run longer
  • Flyguy55
    • 218
    KV is 1900
    4S1P 5000s or better 2P
    5s would be 32,500 rpm , pretty hot set up
    • Eyekandyboats
      • 1935
      you can do 5s, i would be completely comfortable with that setup
      its a D wind do it pulls amps.
      use the biggest batteries you can afford
      EYEKANDYGRAPHICS
      www.rclipos.com
      • Stealth Assassin
        • 610
        • Flyguy55
          • 218
          D wind pulls more amps then a Y wind. A simpistic explaination. A D wind is wound in parallel. less resistance, more amps .
          A Y wind is wound in series . more resistance less amps .
          • Stealth Assassin
            • 610
            Very helpfull Info. Thanks,
            Derrick
            • Eyekandyboats
              • 1935
              yeah sorry. i had a late night last night so i wasn't all together
              EYEKANDYGRAPHICS
              www.rclipos.com
              • stephenszj
                Junior member
                • 5
                thanks. If i got a 5s around 4200 that puts out 240 max amps will this keep my battery temps down? Will i go faster? should i change props to a smaller prop? with more amps going to the motor?
