Rebuilding my BlackJack
  • CodeRed225
    • Feb 2009
    • 42
    I did 7 seven coats of white for my base.
    It was going good until the last coat then I got some popcorn effect. Hopefully I can sand it out.
    • CodeRed225
      • Feb 2009
      • 42
      Originally posted by CodeRed225 View Post
      Okay, I'm gonna play around with mounting it different. What about extending the power wires? Bad idea as well? They don't give you much room to work with.
      Never mind... plenty of wire with it up there. Much better.
      • CodeRed225
        • Feb 2009
        • 42
        Should I mount it right to the floor or get it up off there a little?
        • TheShaughnessy
          • 1461
          Up off the tunnel a lil bit if possible. Also when doing fiberglass remember resin isn't really what gives it strength. You don't want resin rich parts . Your hatch mod looks like a lot of resin was used vs the amount of fiberglass
          • CodeRed225
            • Feb 2009
            • 42
            Good to know. I don't know jack about fiberglass so it has been a learning experience. There is probably more resin used than needed. All I know is the hull is a whole lot stiffer than before. I only did one coat of resin after I trimmed the mat. I'm not really happy with how that is turning out, so I'm still trying to find a replacement hatch for it.
            This is my first go at any fiberglass work. I have worked with resin before but never layed mat. You got to start somewhere though right? Thanks for the advice.
            • CodeRed225
              • Feb 2009
              • 42
              So I already painted inside the hull because I thought I was done in there. Now I will need to epoxy a mount for the esc. Will the paint mess the bond? I am using straight fiberglass resin and ca glue, not z poxy or anything like that.
                Yes you need to clean and sand the area for the mount,
                Or anything else to be mounted to the hull with epoxy or resin and or glue.
                And the mat gives it the strength to hold things in place with a good clean bond.
                • CodeRed225
                  • Feb 2009
                  • 42
                  One step forward, two steps back. s#%t!
                  • CodeRed225
                    • Feb 2009
                    • 42
                    Does anyone know how long should I wait to wet sand after painting? I used Krylon Fusion. The can says recoat before 24 hrs or after 7 days. A week seems excessive but I don't want to rush anything and take another step back. I've got two more colors I want to put on. I don't want to put tape on to early.
                    • iop65
                      • Mar 2013
                      • 367
                      when i have to apply tape i also wait at least one week ,otherwise there is the risk of pealing of the paint underneat when removing the tape!
                      it seems a long time but paint from a spray simply can isn't completly hardend in a few days ,its seems dry but that's about it
                      • CodeRed225
                        • Feb 2009
                        • 42
                        Its been a busy weekend but I did get the boat running, I just haven't kept up on documenting it. Let me try to catch up.
                        I wet sanded the paint job and it came out pretty good. I've decided to leave it white this summer then in the winter I'll put the color on.
                        I sanded out some spots and epoxied some mounts for the esc in front of the motor
                        It came out awesome, it is off the floor, secure and isolated and easy to remove.
                        • CodeRed225
                          • Feb 2009
                          • 42
                          I decided to polish my hardware.
                          Before
                          After
                          • CodeRed225
                            • Feb 2009
                            • 42
                            I ran it today and was very happy with how it handled. I was running a x642 s&b. Temps were around 100 deg f for the motor and esc. It was solid, never came close to flipping. It is a lot heavier then stock... I think that has a lot to do with how it handled. I need to get some more props to try. We are looking into getting a small gps to check speed. Right now I am guessing I am around 50 mph. The cool thing is I could pull full throttle runs and not flip. Also I could turn pretty sharp and fast.
                            • CodeRed225
                              • Feb 2009
                              • 42
                              Oh yeah, forgot to mention, I layed a layer of glass over some battery straps. This worked really good on the first run. Held the batteries real good.
                              • CodeRed225
                                • Feb 2009
                                • 42
                                Anyone have suggestions for more props? I ran a m445 and still temps were 100 deg f. I just ordered a m545 and a m645 from props 4 u. I still would like some more to try.
