Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Dumas Deep Vee Build - RcBoaters Forum
  • Eggo83
    • 70
    hey guys
    updated pics of my Dumas Build, just about ready for some skin to go on the maze of supports, might be doing some lightening when the plywood decking is all on, otherwise it might be a tad heavy!
  • andym
    More Go Than Show Prop Co
    • 2454
    That looks good. Is it a kit? and what size will it end up? Take your time and it will be a masterpiece.
    • Eggo83
      • 70
      thanks, its a Dumas Deep Vee 20, finished it will be 24'' x 9'', nice boat for rougher water! i have parts on the way from OSE, KB45 8xl 1700kv motor and 4s lipo should get it moving also.....
      • Eggo83
        • 70
        o and yeah it is a kit, dumasstore.com i think i got it from.
        • Eggo83
          • 70
          Is there a better time? Fresh parts from OSE! Exciting
          -Speed master Strut
          -Speed master Rudder
          -.150 Flex
          -OSE 6mm to .150 Coupler
          -more to come!!
          • Eggo83
            • 70
            Using FE calc i figure i'll stat at like an X432 x435 props?? now i dont really want to buy metal straight away, i know you can get plastic octura props and others also, can somone tell me whats the best way to go with props and purchasing them?
            ps: bottom and sides are on!!
            • Eggo83
              • 70
              Back Again
              hey all
              been MIA for a while but im back on now..and have some more picts of my Deep Vee Build. Up to finishing the hull, i have applied couple of coats of 7008 two part plastic finish (usually used on floors, i prefer this then glassing it) and then will paint. I have yet to complete hatches etc but am in process of.
              Most of internal's have a position but that may all change due to COG later on.
              Comments welcome.
              • Tech Head
                • Dec 2008
                • 74
                Nice build! The DUMAS 20 was, and still is, a nice boat.
                Looks like it is pretty straight build! Lots of work gone into that!
                The last ply boat i did was a hotshot flat nose tunnel.
                Regards, Brett.
                Regards, Brett.
                • Eggo83
                  • 70
                  Hey Brett,
                  yeah heaps of time lol i only make ply boats they are more fun and leave me with more satisfaction when they work and work well. bit heavier but hey just means bigger motor and lipo setup lol
                    I ran the fiberglass version of that boat 35 years ago with an O.S.20 nitro engine. I had set it up with a submerged drive as the plans indicated - that was pretty common back then. Today I'd use a surface drive on that hull, FE or fuel.
                    With a surface drive and the KB45 motor you stated, an x440 prop would be a good place to start. If you want to stay plastic then use a Graupner K40. I'm sure you can increase the size eventually, but to start to dial the boat in, that's what I'd recommend. If you go submerged drive then the smaller props would be better but I don't know what to specifically recommend.
                    http://www.offshoreelectrics.com/pro...od=grp-2317.40
                    • Eggo83
                      • 70
                      cheers fluid...appreciate the help in prop size. I am going surface drive. I found it easier to setup in past boats..It is an older design for a boat but i was after something that could handle some rougher water, and still be fun and fast. I am happy with it, its only my 3rd scratch built boat, its all learning lol.
