Phil Thomas SS45 Q Hydro Build
  • Gary
    • Jan 2009
    • 1104
    Ohhh...its not the pretiest of mods done and I really had to stretch it out to get the batts up front for the wieght but it works. I will try and get a picture.
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      Been awhile. I've been photo documenting the build as I go, but just haven't had time to post. I actually raced this boat Sunday!
      Was looking for a simple, replaceable, 1pc seal for the rudder that didn't require any glue. Found this pushrod seal (traxxas villain I think) that fits the speedmaster rudder hole perfectly. I sized the hole in the transom to fit tightly with the rest of the seal. We'll give it a try and see what happens.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        Rudder and strut mounted. Only used (2) screws on the rudder.
        Made an alignment tool on the lathe. Slip fits into the brass tube and fits into the collet.
        I need to get the correct rudder mount. I have the opposite side (should have the brass breakaway screw on the bottom).
        • Shooter
          Team Mojo
          • Jun 2009
          • 2751
          Stuffing tube glued in. Learning that 'less is more' here.
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            Decided to go back to mounting servos in the tub wall again. Forgot why I stopped doing that in boats, but I'm sure I'll remember soon! Managed to trace this one pretty well. Fits nice.
            Yes, that's a TRAXXAS! Lol! I've had every other servo in the sun fail, but these water proof high torque jobbies do pretty well.
            BTW - There are RC car servo mount backings behind the cloth to thread into.
            Used 3mm machinable rod (I think it's 1215 steel??). Anyways, it's threadable without a die made out of DIAMOND!
            • Shooter
              Team Mojo
              • Jun 2009
              • 2751
              Used an aluminum ball stud from one of my pancars on the rudder side. Hopefully this won't snap.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                Had to step the stuffing tube diameter down to match the strut bushing size. I am running 0.187" with a teflon liner.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2751
                  Made the turn fin and mount out of 6061. Mounted the fin. This actually took a lot more time that I thought it would. Had to make sure the fin mount was square. I set a level across each sponson bottom and matched it to that angle. 4mm bolts. Drilled and tapped into the aluminum.
                  Gotta go. Redwings back on!!!!!
                  • longballlumber
                    • 3417
                    [ATTACH=CONFIG]99270[/ATTACH]
                    Pete, is that 9/32" brass tube through the hull? How much 1/4" brass tube.... Oh wait, I forgot your using Teflon tubing. I would ditch that Teflon if I were you... Just my $0.02 worth.
                    Good job on Sunday! That thing will be class of the field soon.
                    Later,
                    Ball
                    • phil t
                      • Feb 2010
                      • 195
                      Like the servo mount in the wall, those engine well are plenty strong. the traxxass seals are great too just require a 3/8 hole and pull thru, I have used them on my boats.
                      Phil Thomas
                      email supersport45@aol.com
                      http://www.philthomashydros.com
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2751
                        Thanks Guys. I hope it will be competitive this year. I gotta get the CG figured out.
                        Here was the maiden run that Bob filmed (X442, slow and stable): http://youtu.be/Ja4cAWrO52w
                        Mike - Lol! I thought you might comment on the Teflon. I've had it in every boat except for (1). It's just always worked for me.....seals well and I seem to get away with lighter oil. No doubt, it IS an extra thing to go wrong. I've just always hated the loose fit of the 1/4" brass and 0.187" cable.
                        I was talking to Jimmy about teflon on Sunday and how to restrain it by CA-ing the first 1/2" into the stuffing tube (sanded both the Teflon and the brass prior). Here's a pic....
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2751
                          Here are a couple pics with batteries. The protech straps really work well to hold the cells.
                          Speaking of batts, so far I am liking these 'pulse ultra' cells. The heli guys seem to like them too, and they were avail at the prop shop, so I figured I'd give 'em a crank. So far, so good....and my reference is a pair of hyperion's!
                          • jfrancisco892
                            • Feb 2012
                            • 593
                            [ATTACH=CONFIG]99445[/ATTACH]
                            Thanks for the tip pete. Definitely gonna use that in my p sport.
                            • Shooter
                              Team Mojo
                              • Jun 2009
                              • 2751
                              Been way too long since the last update. I've been taking photos along the way....
                              Made this contraption to hold the boat while I painted. The vice holds the rod and allows for rotation. The second C-clamp is a safety incase the vice ever lets go. 20130603_203957.jpg
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2751
                                I used Klasscote per Mike's suggestion. Couldn't be happier.
                                1st coat of primer....
