Very Mean Mean Machine
  • Basstronics
    • 2384
    TP Power CNC 45mm X 1.4P
    I got an M445 also... hmmmm
    • Heaving Earth
      • 1929
      If you got some 5s packs you'll hit 60
      • Heaving Earth
        • 1929
        The larger one looks like a fc cheetah. They can do single power
        • Chrisg81983
          • Jul 2011
          • 1585
          Good luck with maiden should work out well. I am glad you resolved the rudder bracket issue.
          • Bomber Z
            • Oct 2012
            • 24
            #35
            You can still put a little more bend in the tube and set your drive down more.
            • Heaving Earth
              • 1929
              #36
              Here's where mine is set if it helps ImageUploadedByTapatalk1376841321.185900.jpg
              • Basstronics
                • 2384
                #37
                Mine is set flat on a flat surface. She has a lot of rudder... Spin out turns... Pretty fast, probably low 50's.
                The TP Power water jacket is going in the trash. Its junk. I need to reset the ESC. I thought I had it all setup but it had the break on. She thermaled or something out in the water. Couldnt tell. When it got back in to shore the motor was about 130...
                • Bomber Z
                  • Oct 2012
                  • 24
                  #38
                  Does anyone know if the transom higher on the old M/M's then the newer one? Looking at the picture it looks thinner then mine.
                  • SirBudman32
                    • Aug 2011
                    • 701
                    #39
                    My rescue boat doing what it does best, rescuing Basstronics boat....
                    Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                    • Basstronics
                      • 2384
                      #40
                      Theme music:
