Twin brushless V-Hull
  • Pråmskepparn
    • May 2011
    • 16
    Hello, just wanted to share this build, heres what i got so far
    It is an 80cm Deep-v fiberglass hull.
    I was thinking submerged drive, either twin 2845 2000kv on 3s or maybe a single 4050 2260kv on 3s, any thoughts?
  • Spot Me 2
    • Jul 2008
    • 769
    The rudder is mounted WAAAAAAY too low....
    MMGMMarine
    RobertsonRacing
    • iridebikes247
      • 1528
      Definitely need to lift the rudder up like 2 inches.
      • Pråmskepparn
        • May 2011
        • 16
        When on plane only 2 inches will be in the water
        Remember im going for a rigid shaft submerged drive where the prop exits under the boat
        • iridebikes247
          • 1528
          You'll get a lot of drag at low speed. Your boat but I made this mistake awhile ago and the boat performed horribly when turning at low speed.
          • Pråmskepparn
            • May 2011
            • 16
            I'll try, if the rudder is too low i can move it higher.
            As i will be running in saltwater i will try to keep it as watertight as possible, hence the walmart box
            Im thinking of a 40xx motor turning a big prop at reasonably low rpm, maybe a 4074 2000kv on 3s?
            • Pråmskepparn
              • May 2011
              • 16
              Okay, just ordered this from hobbyking
              XK4050-2260KV Brushless Inrunner
              NTM Prop Drive Series 35-36A 1800Kv / 875w
              Birdie 70A Brushless Boat ESC w/5A BEC
              HXT 6.9kg / 39.2g / .16sec Twin bearing servo
              Turnigy 5000mAh 3S 20C Lipo Pack
              and a solid 4mm axle from a local dealer. Any suggestion for prop and connector motor-axle?
              ....hope the cheapo ESC works
