BBY Micro Turbine Hydro for SSSH
  • Dr. Jet
    • 1707
    #136
    Hmmmmm..... I like it. It looks vaguely familiar though........
    A nation of sheep breeds a government of wolves
    • J Solinger
      • Apr 2008
      • 197
      #137
      I stole it from a guy that knows about this stuff.
      Joe Solinger
      • RandyatBBY
        • 3915
        #138
        Originally posted by dostacos View Post
        so early we race the hydros and when the wind comes up it's FOOTY time
        I have my hull {ebay probably would have been cheaper to get a new one. } I ended up removing his motor mount, rudder and drive line that was rather grungy. I did get a brushless motor with no name.
        motor/esc/battery on the way
        need strut/rudder/prop bby and MHZ USA are both out for a few days and Fuller does not have everything, may go with his anyway {he only is missing a prop}
        I am back in the shop today if you need anything.
        Randy
        Randy
        BBY Racing
        • RandyatBBY
          • 3915
          #139
          Originally posted by J Solinger View Post
          Here is a drawing of the new linkage design. Hopefully I can get some machined in the next day or two. I am getting ready for a race this week end and time is tight.
          I hope this will be taken constructlively, with the leading edge of the rudder so far behind the piviot point it will take a lot of power to turn the boat. Small servos will not work well it will take a stronger servo to move the rudder. There is more if you want my advise.
          Randy
          BBY Racing
          • Dr. Jet
            • 1707
            #140
            Hmmmm..... You have a point there Randy. I'm using an old Cirrus CS-20 (minimal torque), so I suppose I will be the guinea pig on this. Testing will occur soon.
            • J Solinger
              • Apr 2008
              • 197
              #141
              That has been a concern of mine too Randy. Technically it is only about .156" from the leading edge to the pivot point, but it is a small servo. Your expertise is always welcome Randy.
              Joe Solinger
              • RandyatBBY
                • 3915
                #142
                Ok hear it goes. The pivot point of the leading edge of the rudder has a big affect on the handling of the boat. If you add to the edge to put more rudder infront of the piviot this will give you power steering. How much is determed by the power. With Extereme high power I find that the leading edge needs to be on the piviot point. With less power you need more edge foward. This is the best infomation to this point of my testing.
                I really like the auto cad picture it helps me see a lot. Wish I could do it.
                I allso have problems with the way the flow of the water that comes off the hull and runs into bracket that holds the rudder.
                It is late and I need to spray some molds and go home and sleep, more tomorrow as I have time. I hope this helps.
                Randy
                BBY Racing
                • Dr. Jet
                  • 1707
                  #143
                  Testing Scheduled
                  Some of the SLOBS will be at Santee Lakes this Saturday (July 26) early in the am. The MTH will undergo sea trials at that time.
                  • Dr. Jet
                    • 1707
                    #144
                    MTH Results
                    The BBY MTH is getting there. Speed was right there with the MHZ shovels. It was hopping pretty bad at first, then I started to go down in prop size/pitch and it helped. So did moving the battery back. The ride pads overhung the outer anti-trips and I think this gave me some erratic cornering (see video ). I have now sanded them off and have a sharp anti-trip. The servo mount was a bit soft; I've firmed it up now. It seemed to need a lot of left trim. Future ply frames will have an offset motor/driveline. I adjusted the turn fin angle a bit to counteract the tendency to turn right.
                    Looks like more testing might be in the works next weekend.
                    Videos here:
                    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                    • Dr. Jet
                      • 1707
                      #145
                      More testing scheduled for this Saturday.
                      • J Solinger
                        • Apr 2008
                        • 197
                        #146
                        Good luck. I will be watching for photos.
                        Joe Solinger
                        • J Solinger
                          • Apr 2008
                          • 197
                          #147
                          rudder update
                          Ok, here are a couple photos of the updated rudder. I have moved the linkage pivot point up parallel with the hinge point. This will reduce the control rods side to side motion to a minimum.
                          Joe Solinger
                          • Dr. Jet
                            • 1707
                            #148
                            Looks good Joe, I'll have to order a pair of arms from you.
                            I ran the MTH again today, I still did not have enough rudder. When I got home, I put a longer arm on the servo to increase throw.
                            Tail-hopping has been cured with a relocation of a few componments, allowing the battery to slide back. speeds are the same as the MHZ hulls.
                            • J Solinger
                              • Apr 2008
                              • 197
                              #149
                              I will send a couple off to you to replace the ball joints you have.
                              It sounds like you are having good progress, WTG.
                              Joe Solinger
                              • Dr. Jet
                                • 1707
                                #150
                                Joe,
                                I'm getting close. I'm happy with the way it rides, and the speeds. The straight shaft works well. Trimming the ride plates helped a lot with the cornering. I added a small non-trip to the inside of the right sponson to see if that would also help. If I do another run of wood frames, I will offset the driveline to the right by 1/4" or so to counter propwalk, and maybe raise the prop by about 1/16" or so. I still have a couple of the first run of frames, so I will let some of the SLOBS have them to try out.
