HPR 135 Bulletproof Build
    Geez,two Schulze's my friend Oohh,$$$.Did they shut down or smoke?
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      #137
      Not smoked, drowned
        I have had a couple Castles shut down from being wet. I reset them and off they went,and still do.BUT,it wasn't under the fly when they got wet.
        • Chrisg81983
          • Jul 2011
          • 1585
          #139
          No smoke or nothing shawn they just shut down they smell new still lol
          • graill
            • 407
            #140
            Cant believe I missed this thread, too busy I guess. Beautiful work so far Chris. You should think about getting the Schulze 300's or at the very least have the modified 40.160/1's for safeties sake. Nice to see you put the effort into making a nice looking rig. You will need to add weight, she is begging to blow over.
            • ManuelW
              • Oct 2010
              • 786
              #141
              problem with either Schulze is where to get them and especially where to have them serviced with Schulze being out of business at the moment? The 40.161 would work nice on that setup, the YGE160HV is great but could be pretty close to the limit on X457.
              regards,
              Manuel
              • jcald2000
                • 786
                #142
                Note on the cooling lines, the silicon lines were blowing off so I changed to the nitro fuel line on all my boats, no more problem in years.
                Just spread the ends of the fuel line with a pair of needle nose and push them on then zip tie. Works even on non barbed tubing at 90 mph.
                • Livewire121
                  Fast Electric Adict!!
                  • 320
                  #143
                  Sorry to hear about your Schulze's, I've had my T-120's shut down as well when they got soaked. I sat them in a container with some rice for a couple days and they came out fine, hope you have the same luck!
                  Hey I almost forgot....take it easy on those YGE 160's, I want them for the 115 lol.
                  HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
                  • Chrisg81983
                    • Jul 2011
                    • 1585
                    #144
                    Richard I need to thermal them a few times before I can get rid of them. Lol at grail / James thanks for the kind words
                    • Livewire121
                      • 320
                      #145
                      Please be kind lol
                      • Livewire121
                        • 320
                        #146
                        On another note I got the rest of the parts for my EKOS, I hope I can maiden her this sunday!
                        • iridebikes247
                          • 1669
                          #147
                          I was in the area drove down to see the lake I haven't used the boats much lately as one is apart trying to get the mystic ready. Hope your escs dry out that's rough dude.
                          • graill
                            • 407
                            #148
                            Along with what jcald200 said about the slight lip on the brass tube are the spring clamps that Great Planes sells. 4 different sizes, and they are made for pressurized systems, which is what a water intake line is unless you add a small restrictor and drill it out to reduce flow a bit.
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              #149
                              I actually barbed all the brass fittings and now she has no problems Thanks all for the ideas..... today I ran her with the yge 160's and a set of 5014/2 from propshop. She ran very well but water was too rough to really let her go. I will do more testing sometime this week.
                              • iridebikes247
                                • 1669
                                #150
                                Chris I have a set of 5518 fc cnc props 3 blade you can borrow if you'd like this weekend. idk if this is too much pitch or whatever but either way they're not on my boat at the moment.
