How to: marinising a HiModel GX200Amp ESC by Tyler
  • tylerm
    • Nov 2007
    • 310
    Got my HiModel ESC a while ago, and have finally got round to marinising it.
    I made a cooliong plate out of 1/32" brass sheet, 7/32 brass channel, and 5/32 brass tubing.
    Then i "Glued" it to the top layer of FETs on the ESC, using titan nano thermal grease from DSE.
    Tomorow night i will cover the WHOLE thing in DP270(electrical potting epoxy) like you do a reciever.
    Tyler.
  • Heath M
    • Mar 2008
    • 806
    Hi Tyler,
    Looks good,but a fan would have been much easier and does the job better IMO
    Here's a thread on coating it in epoxy, Please read before you do it..
    Discussion waterproofing a 200amp esc with dp270 ?? Racing Boats - Electric
    Heath
    Brisbane,QLD, Aussie
    • ghostofpf1
      • 392
      Originally posted by Heath M View Post
      Hi Tyler,
      Heath
      LOl...that's my thread and I'm still undecided if I want to simply go with a fan and the best waterproofing job I can hope for in my hull or use the DP270 and soak the esc in it ....
      decisions... decisions ....
      Ghost
      • tylerm
        • Nov 2007
        • 310
        Hi heath, the fan may work just as well but before i tore into this i was talking with ray and getting his advice. He said they just grind the original heatsink to put tubes in, but i wanted to make my own cooling jacket/plate. It will have heaps of thermal mass which was what i wanted. With the big mass of water in it as well it should move the heat well. I'm not a big fan(no pun. int.) of moving things like fans in my hulls. I will lighly coat it in DP270 and heat it like andy recomends to waterproof it.
        Tyler.
        • Flying Scotsman
          Fast Electric Adict!
          • Jun 2007
          • 5190
          Looking at your picture you seem to have cooling only at the top. The bottom fets will still produce considerable heat and in this case i think fan cooling is a better option.
          Douggie
          • tylerm
            • Nov 2007
            • 310
            I would have preferred to be able to cool the other layers of FETs but because there sandwiched to the next board with thermal tape, its not possible. On the bottom of the bottom board there are no fets to cool.
            Tyler.
            • Jeepers
              • May 2007
              • 1973
              IMO that would be kind of a waste to make a cooling plate that doesnt contact all the FETs. to me its a source of possible leaks and extra weight. use the brass to make a screen for a cooling fan.
              Each to his own methods however.
              • tylerm
                • Nov 2007
                • 310
                Indeed.
                Guys are using these esc's with 1521's cooled similarly to mine with no problems, so i'm happy.
                One thing i will do differently next time is use heatsink rtv compound instead of thermal grease, much easier when it comes time to seal it up
                The fets on the 2 lower boards are pushed up against the other boards with thin thermal tape, which means you cant get cooling plates in between.
                A fan will circulate air around, but thats not much use if your going to seal up the esc
                Tyler.
                • Stealth Assassin
                  • 610
                  Reddy made a good point about the south having alot hotter water temp and he's right. I fan cooled my turnigy and It works very well on 4s with temps In the 90s.
