Mystic 29 rebuild
  • JimClark
    • 5913
    Mystic 29 rebuild
    Ok going to start a thread and show how I am going to rebuild this boat. Here is what I have done so far
    All hardware is stripped off.
    The wood with the blind nuts to attach the strut and rudder has been replaced with a piece of 1/8th aluminum glued in with Devcon epoxy. going to either tap into the alum backing plate or thru bolt the fasteners.
    Going to fill several holes that are not needed.
    Going to strip the paint if I can find something that will work on this paint. So far 0 for 2 on the strippers.
    New stuffing tube will be installed also.
    Going to race in the spec class and use a UL-1 motor or maybe try a proboat 1800 kv I have both.
    graphics are going to be an Air Force Thunderbird theme
    Pictures will follow
    Billy Graham
    Sound like fun,
    And I know it will be nice Jim.
    • G1ST
      • Dec 2010
      • 351
      Watching closely Jim
      I just finished my Mystic rebuild last weekend.
      Hull and hardware are stock. I am using a UL-1 motor, a T120 and a M445 as a baseline.
      It's ready to go but the work thing is getting in the way on running it.
      Greg
      • JimClark
        • 5913
        well finally made some progress this weekend.
        Layed glass in the sponson's to strengthen
        all wood is now sealed.
        Sponson's are getting blueprinted
        two hiles are now plugged with glass and epoxy to fill the hole
        Also got the stand built next sand it and stain and put poly on it.
        Billy Graham
        • JimClark
          • 5913
          Ok finally got around to taking some pictures
          First one is the sponson Blue printing (leveling ans sharpening of edges0
          uSED FIBERGLASS TAPE ON THE INSIDE WHERE i AM PLUGGING EXTRA HOLES
          Hole filled on the outside with system three Sculpt wood http://www.systemthree.com/store/pc/SculpWood-c21.htm
          Added .125 aluminum backing plate to replace bad wood in transom
          the stand
          Billy Graham
          • JimClark
            • 5913
            Added two layers of glass in sponsons to stiffen up where batteries go
            Added Glass on the inside of the canopy to stiffen it.
            Billy Graham
            • Darin Jordan
              • 9446
              Ummmm... Hey... I need a stand (or two) like that! :) Did you make patterns??
              Darin E. Jordan - Renton, WA
              • JimClark
                • 5913
                No I didn't but I still need to tweak it and after I do that I can make a set of templates for you. I usually go into a build like this with a general concept and some rough dimensions and chance things up as I go.
                Sent from my MB611 using Tapatalk 2
                Billy Graham
                • JimClark
                  • 5913
                  All sanding done on the hull and the stand has meen stained and two coats of poly on it
                  Billy Graham
                  • monojeff
                    • Nov 2010
                    • 2728
                    Nice work Jim I should have some dimensions on the decals we talked about soon.
                    I need to get those props done for you also!!
                    OSE GIFTING ELF
                    HAPPY HOLIDAYS!!
