NOTE: Anyone reading this should know that Phil has updated his molds and his current PT Stealth 30 (Version #2) meets the currently NAMBA rules. My hull was purchased before he updated the molds to meet the rules.
Hey group,
I haven't post much lately with pictures so I thought I would document the modifications to my Phil Thomas Stealth 30 to meet the NAMBA transom rules that I started today. If you recall; there was some discussion about a year ago about the boat not meeting the 65% transom rule. The actual rule can be found in the NAMBA as stated below.
Section 28: Page #9 vii) The width of the transom bottom shall be no less than 65% of the
width between the inside edges of the front sponson planning surfaces.
An exception to this will apply to scratch build scale designs of full
sized boats that are full bodied 3 points hydroplanes but have an
afterplane that tapers sharply at the transom. Example: Lauterbach
shovelnoses.
Here are some pictures of the hull with measurements before I started doing work. As you can see the measurement of the “inside edges of the front sponson planning surfaces” is (roughly) 11.125”. 65% of 11.125 = 7.25 (7.23125). You can see in the pictures the transom at its point nearest to the water line is around 6.75. This means I will need to add .75 (total) .375 on each side to meet the measurement. An interesting note to point out is; my hull (version #1) there are two little air traps that Phil put in to the transom to help “pack” some air and lift the transom. Those “nubs” are roughly .125” on each side taking up .25” of the total width. I would like to note the actual transom width is 8” meeting the rules. It’s the non-trip width that everyone seems to be reading. Take a look at the pictures below.
Another thought that I had today while reading the rule before hacking up my boat; is they don’t tell you in the rule book where to measure your transom (i.e. upper or lower). I was corrected below by Fluid on my reading of the rules....
Hey group,
shovelnoses.
I missed that one...
I should have re-read it closer. It's been awhile since we had this discussion. It was an honest mistake.
