bby carbon outrigger
  • RandyatBBY
    • 3915
    well that foilSim program is interesting it did tell me a little hint, Now I need to work it more.
    Randy
    BBY Racing
    • ktmakias300
      • 47
      go for it randy i believe in you
        • 9479
        Let me get mine built then we will talk. One mold left to do.
        Randy, I talked with someone else today and now this may make 4 of us
        twin PSpec power could be a hoot!
        • RandyatBBY
          • 3915
          Originally posted by Mike Caruso
          Which version of FoilSim? It is just what I am looking for. I started with Beginner it is very cool.
          Thanks Mike
          Randy
          BBY Racing
          • ktmakias300
            • 47
            my friends i respect your big experience in boats but some things must be checked from some programs like that....this is going to make you think about some things that you maybe never have thought in the past.......keep going
            • ktmakias300
              • 47
              here some pictures
              • ManuelW
                • Oct 2010
                • 743
                shape of the rigger looks awesome. But thrust me, you can almost completely forget the results of foilsim for our application. Its pretty precise for a free flow over and below the foil, but in our application we run these very close to the water surface and ground effect has a major influence which changes everything. If you use a simulation software where you can take that into consideration and adjust the heigth of the foil above the ground, then it makes sense!
                regards,
                Manuel
                • ktmakias300
                  • 47
                  i am totally agree with you manuel.and i have adjust the height of the foil above the ground and i think i am 70% correct to my results. i have a lot of research to do but i think i am going to have a good result....
                  • ktmakias300
                    • 47
                    first test on the water with small propeles
                    • RandyatBBY
                      • 3915
                      Water looked rough, but good start. Got any pictures of the boat set up?
                      Randy
                      BBY Racing
                      • ktmakias300
                        • 47
                        thank you randy for everything ...here some pictures P4030151.JPGP4030147.JPG
                        • ktmakias300
                          • 47
                          second run with my outrigger from randy!!!!
