Scratch pontoon boat build
  • wakeboardfusion
    • 514
    I have started a pontoon build with some extra parts and an ep1 I had laying around. Pontoons are black ABS 2" pipe, I know they may be a bit heavy to float well, but one 24" holds over 3 pounds, so with two 24" and one 10" it should hold the weight. I found eggs from hobby lobby, cut them in half for the front and back of the toons. Motor mount is 1/2" ply. Here are some pictures so far.
  • Cooper
    • 1168
    Looks pretty cool so far. I too have taken interest in the scale builds. Just finished up a springer tug. My neighbor was looking into building a pontoon so I'll forward this thread to him, and maby he has some ideas. I'll keep watching. :)
    • wakeboardfusion
      • 514
      Got the pontoons mounted and did a test fit on the motor. I need to epoxy the underside to waterproof, what can I dilute 2 part epoxy with to coat it?
      • Cooper
        • 1168
        Some say denatured alcohol , me, acetone , a little bit goes a long way. As long as you are using a slow cure epoxy. You don't want the epoxy to set up before the thinning agent evaporates if so the epoxy will not harden to a desirable degree. I'm not an expert so see what others say. And if its a coating then ok but structural I would not thin but use the appropriate epoxy. Finishing resin should be thin enough to coat. Again just my opinion as I may be wrong So see what others say also.
        • BlackSnakeRacing
          • 59
          when i do my scratchbuild airboats from ply i usually use finishing epoxy, its alot thinner than 30min and is easy to spread/brush on and gives a good seal. I have 2 that are over 3 years aold with alot of use on them and they are still in perfect nick, no water has started seeping through the epoxy. I run them across the water and flat out up the bank and back to the car along a rocky track
          Cars and planes are for fun... Boats are for serious racing Bust Out Another Thousand
          • wakeboardfusion
            • 514
            If I primer/paint the wood should I still use finishing epoxy or is that just added weight?
            • BlackSnakeRacing
              • 59
              i epoxy then paint over the top, if you paint first the epoxy doesnt bond as well and can peel off in my experience. First one i built i tried painting first and when sanding a few lumps out of thye epoxy it was peeling off in my hands after 3 days cure time.
              • philg
                • Jan 2013
                • 2
                I`m looking at building a pontoon as a camera platform for cataloging the local wildlife on the wetlands where I live.
                I will be watching this build with interest as this will be my first boatish build.
                What total weight are you looking at,and what motor are you using?
                cheers.
                • wakeboardfusion
                  • 514
                  Phil- I am going to use the stock EP1 outboard and motor. Not sure if I will use a traxxas XL5 waterproof, or a water cooled ESC yet. (not sure I will need it) As far as weight, I am just ballparking at 6 pounds. The pontoons should be able to float 10, but I will have to do a float test to verify that.
                  • wakeboardfusion
                    • 514
                    It weighs in at 4.8 pounds as it sits. As you can see with a 3 pound weight it is a bit heavy. I'm sure the boat will float, but I need to make it on the lighter side.
                    • philg
                      • Jan 2013
                      • 2
                      Thanks for the reply and info mate.
                      My machine is made of 100mm PVC pipe and aluminium top plate, and so far weighs 10 pounds.
                      I`m looking at this motor http://www.hobbyking.com/hobbyking/s...dproduct=17707 running on 4S to start with.
                      I`m still looking at which ESC to use.
                      I`ll post something as I get it together.
                      • iridebikes247
                        • 1669
                        This thing is really cool, nicely built. looking to build something similar this summer that can pilot a 6 pack of beer out to my friends swimming on the lake haha. Anyway good luck with it!
                        • Darin Jordan
                          • 9446
                          Looks like it would be excellent with a pair of Pro Boat Stiletto Outboards mounted... One on each sponson! A pair of 1500KV MG motors on 3S instead of 4... would be just about right!
                          Darin E. Jordan - Renton, WA
                          • wakeboardfusion
                            • 514
                            Two of those will push it very well. I am hoping to get my shipment of finish resin from HK soon to get back to working on the boat
