Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 frist rc boat build - RcBoaters Forum
frist rc boat build
  • revo6.6
    • 7
    frist rc boat build
    Hello everyone.
    I have a friend who has a villeinex and I drove it. Now I want to build a brushless boat. Is this all I need.
    lipo
    bec
    hull
    rudder system with Assembled .130 able for 1/8" Props
    coupler 5mm to .130
    linkage boots
    Aluminum Large Water Outlet (oce)
    servo mount
    Octura x435 (cheaper one) prop 1/8 shaft size (oce)
    feigao540L: - 540 10L 2,458 RPM / Volt 5mm Shaft
    OSE Water Jacket for Feigao 540 Sized Motors
    esc 70amp
    esc programmer
    3.5mm female conecters
    servo
    receiver
    (already have traxxas transmitter)
    crystal
    water prof receiver box
    What do I need for the starting linage? Also is there any thing else I need?
    thank you in advance
    traxxas vxl rustler and custom e-revo
    working on custom rc boat
  • blastoff
    • Apr 2008
    • 171
    I have seen radio combos with servos for around $50.00. For just a few $ more over the cost of the traxxas you could get a a hole radio package (of the same quality)
    AND for another $15.00 You could upgrade to the 100 Amp controller.
    Just my 2cents
    Good luck with your build !!!
    • blastoff
      • Apr 2008
      • 171
      Oh ya i like the Traxxas radio box !!! I will get one myself.
      • revo6.6
        • 7
        what rods do I need and were do I get them for the linked
        • revo6.6
          • 7
          deos this include the everything for the drive lane. rudder system with Assembled .130 able for 1/8" Props
          • Rex R
            • 1007
            dunno if that radio box will fit under the hatch...its kinda tight in the vertical. do get hatch tape. I use 2-56 servo linkage from the lhs (airplane supplies). ayup you get everything need for the drive line(sans prop) although a nylon insert 5-40 locknut to replace the supplied bullet propnut would be a good idea.
            • revo6.6
              • 7
              thank you very much. I was wonder about that. as you can tell im new at this
              • revo6.6
                • 7
                also how do the X-Power Brushless 70a Esc. handel lipo cutoff
                • Rex R
                  • 1007
                  motor/battery choice:
                  motor is too hot a wind for a 4s(14.8v) system(imo), a 7 or 8l on 2s(7.4v) with the 100a esc would be a better choice.
                  electrical connectors:
                  minimum 4 mm(5.5mm would be my choice) 3.5mm will get HOT.
                  • NorthernBoater
                    • 869
                    For batteries I would choose either of these and run 2 packs in parallel. for just sport running. Both of these packs are very reliable.
                    http://www.rclipos.com/RCL.html
                    Elite EL2S-3300
                    Poly RC PQ-3000XQ-2S
                    The Speedmaster system is also very good for monos. You will need a turn fin and possibly trim tabs. You would want to run it without the trim tabs first to see how it runs.
                    • revo6.6
                      • 7
                      well guys I was charging my 6k 3s lipo fir my rustler vxl (fun truck) and my charger started smoking. It was a nice one, stuck with my old and trustly duratake twin.. Anyway, this means im stuck with nimh battery's. I was thinking running these in Parallel for long run time. what you think. click
                      also anyone know when the x-power 100am esc will come in stock
