DF 35" Pirate 1st build
  • Savage Skidoo
    • May 2011
    • 359
    #46
    i got some more done ... put a wrap on the motor mounts . thanks for looking .
    www.facebook.com/Boaters and Crawlers Durham
    Durham Off Road Rc Club - www.dorc.ca founding member
    • Savage Skidoo
      • May 2011
      • 359
      #47
      i know i've been lax'n got some laminating done as i did not want to drill through the hull to fix the lay down servo mount here are some pic's enjoy
      • Savage Skidoo
        • May 2011
        • 359
        #48
          • 9481
          #49
          looking good!
          what motor and kv are you going to run in this ?
          • Savage Skidoo
            • May 2011
            • 359
            #50
            Thanks Brushless55 , in it is a 4092-1430kv and T180 on 2-3s 5000s . Some help on a prop would be awesome , in my box i have a p215 , p220 and a x442 . I have had lots of practice SBTR props as ive been the go to guy around here , some times putting my work behind . Thank your for the reply and looking .
              • 9481
              #51
              I would start with the P220 and work up..
              you may need bigger props for this one and it should really move out nice
              • Savage Skidoo
                • May 2011
                • 359
                #52
                I've put some power to this beast and looks fine so far . This is the vid i shot of it . CLICK on the picture .
                Some fine tuning now , the bow has 2 part foam in it . Heres were i need some help please .......dose any body have any ideas how to keep the hatch closed . thanks Mike
                • Savage Skidoo
                  • May 2011
                  • 359
                  #53
                  Heres a short vid from my Maiden voyage , the p215 was ready to go so i used it but lost it in the drink . I did not GPS it , as i was checking for leaks and cog otherwise it ran great , now for the right cleaver on the rear it will be sweet :) . Thanks K.A. for the Video
                    Looks great! Congrats!
                    I used those billet trim tabs on my MHZ Lizard Xtreme, love them, they look awsome on your boat! Great build, all the CF work done beautifully!
                    • Savage Skidoo
                      • May 2011
                      • 359
                      #55
                      Here's another vid done by depro , thanks for looking
                      • Savage Skidoo
                        • May 2011
                        • 359
                        #56
                        I had 3 back to back runs this weekend , flawless runs . I've been working on a prop i got from kintec , its a P235 ........nice step up from the P220 runs cooler and WAY WAY faster . This weekend coming will get some vid's and GPS it .......
                          • 9481
                          #57
                          great to hear man!
                          bigger prop and runs cooler, can't ask for much more on 6s...
                          • Savage Skidoo
                            • May 2011
                            • 359
                            #58
                            I will also share this prop anvil i made with you , i cupped the P235 for the test run .
                            • Savage Skidoo
                              • May 2011
                              • 359
                              #59
                              Not the quickest boat on the market but i'll take it , GPS' it , now for some tweeking . I have a question for some of you more experienced Fe boaters . The boat gets up and goes at half throttle , i pull the trigger to full with no increase in speed , 971687_10151665453940692_354226127_n.jpg
                                Could be the LVC(low voltage cutoff) kicking in. That is a SK or T-180 in there right? I have mine programmed to 5s and 3.2 volts. Auto detect will cause this. Also make sure your throttle is calibrated.
