59'' Outerlimits SV43 "Voltaic"
  • Heaving Earth
    • 1929
    This is so badass
    • iridebikes247
      • 1669
      This boat is ridiculous. I'm really liking the look of big super powerful v hulls. I think it has to do with all of the hardware hanging off the back the back of this boat is intimidating.
      • Rumdog
        • 6667
        Such a cool build!
        • Rocstar
          Joel Mertz
          • 1536
          Thanks guys, this one might take some time to complete. I can only move as fast as my wallet will allow.
          Installed the hatch bolts. The sides were a little narrow, so I added small cf tabs to mount to.
          • Jason4636
            • 712
            Looking great Joel
            • gyrotron
              • 499
              Joel,
              Are you powering this beast with the 600kv or the 910kv version?
              Thx
              • Rocstar
                Joel Mertz
                • 1536
                Originally posted by gyrotron View Post
                Joel,
                Are powering this beast with the 600kv or the 910kv version?
                Thx
                1050kv on 8S2P
                • twissted
                  • 896
                  I really like this build! I think that I will use this build as a blue print for my next build. I will do a few things different to make it mine but not far from this build. I love it, nice!
                  twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
                  • Karfrik
                    • Jun 2009
                    • 1248
                    Oh Boy!!...I like big toys!!!,....Subscribing!!
                    • PRO PAINTER
                      • Nov 2011
                      • 208
                      yup
                      Originally posted by Remmie81 View Post
                      Very nice hull and hardware! Looking good man!!
                      From the pictures it looks like the trimtabs are mounted level with the bottom of the hull?
                      If so you could better raise them 1,5-2mm otherwise they will create drag.
                      Keep the pictures coming!!
                      Hippie's Airbrush Alley http/:www.theairbrushalley.com
                      • Rocstar
                        Joel Mertz
                        • 1536
                        A special thanks to Fightercat for manufacturing the motor mount.
                        I fitted the motors and it should work out well. I'll be taking this to work and removing some material to lighten it up a bit. It's at 6lbs with the motors as it sits.
                        Next I have to secure this behemoth to the hull.
                        • Jason4636
                          • 712
                          Looking good Joel. I can't wait to a video of it.
                          • Rocstar
                            Joel Mertz
                            • 1536
                            ESCs came in. Because of the way the wires come out the bottom, I needed to come up with a way of mounting them and still look cool..
                            A little 3M Very High Bond 2 way tape...
                            Mounted them to a piece of CF plate.
                            I cut the switch out and solder the wires together. Then mounted the connectors in the grommets.
                            They are mounted to the hull using threaded standoffs and weld nuts epoxied in place.
                            • Rocstar
                              Joel Mertz
                              • 1536
                              • iridebikes247
                                • 1669
                                Probably the cleanest esc setup I've seen. wow to how you mounted the bullet connectors especially.
