MHZ Mystic 56" Mono
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    #121
    Although they look really cool, I would personally go with something shorter. The pull/pull is like a gear, so by having the cables close to the center of the servo and apart on the rudder end, you gain more torque and use more teeth on the pinion inside the servo causing less stress. Just my 2c
    • Jason4636
      • 712
      #122
      The blue one in the pics up above are from helipal.com
      • Jason4636
        • 712
        #123
        I took it out today for the water test. Everything was good to go. I had everything in it, but the esc's. Weight was 32lbs, so with the esc's in it. It should weigh in around 36lbs. I had to send out my esc's to joel for some soldering work. Both of my irons wasn't stong enough to get the job done. So the next time I can, I'm getting a big ass soldering gun. Cause if I could hgave done the solding myself. I would have been testing today. BUMMER!!!!
        (8) 5s 4500mha 65 Dinogy batteries are going to power this behemoth.
        • rscheffer
          • Aug 2011
          • 74
          #124
          Just wondering how are you going to tape your hatch watertight because there is no room next to your screws end your antena holder?
          Ramon
          • Jason4636
            • 712
            #125
            I'm going to use a hatch seal, and pray for the best. I have one on my fantasm, and have crashed at 70mph a few times. With no water leaking in
            • Fast One
              • 220
              #126
              Hi, just wondering if you could shed some info on the ball bearing shaft tube seal units. They look to be water cooled, and what sized brass shaft do they fit onto?. Do you run a teflon liner inside the brass tube?, do the ball bearings help the flex shaft align with the motor coupling?, you must have to get the angle 100% to aviod vibration.
              Please excuse all the questions, I have never seen this method before and was curious to know if it was actually beneficial?, if so where can I buy them.
              Regards Shane.
              • Jason4636
                • 712
                #127
                I'm really the wrong person to ask if they are helpful or not. I haven't ran the boat yet, but from what all I have read. They do help out with a smoother running shaft. The nipple on top, isn't for water cooling. I've seen where people just cap it off, and fill it with grease there. I've seen people put grease fittings in there, and use a grease gun ti refill the shaft. And I've seen people use and oil reservoir, and use some heavy oil in the reservoir.
                Mine came from MHZ in Germany. The ones I got fit a 10mm shaft. But they have all different sizes out there. And yes I am using a liner.
                • Rocstar
                  Joel Mertz
                  • 1536
                  #128
                  The bearings are there for the locking collar to ride against in the event a motor coupling comes loose and keeps you from losing your expensive prop and flex shaft assembly. Without the bearing, the locking collar spinning at high RRM would tear into the end of stuffing tube.
                  • Jason4636
                    • 712
                    #129
                    Finally got everything installed, and let me tell you. Getting all the tubing, wiring, and everything else under the esc covers is a P.I.T.A.!!!! But its all in and been bench tested. Since I got some large size tubing. Who makes the bigger HRC water jacket fittings? I'm going to have to get some larger diameter nipples. Befor I can go test it out. Even with a zip tie tight as hell, it still leaked water.
                    Should I start out with 8s with 5515/3. Then ifeverything is ok move on up to 10s with the same props? Then later on down the road, I'll try ot my 5517/3 and 6016/3
                    In the video I moved my tx to 150% throttle.
                    • Chrisg81983
                      • Jul 2011
                      • 1585
                      #130
                      Jason she looks good man....before I went through all the trouble of ordering new water inlet nipples I would just try smaller tubing first. You will be surprised how much water flows through them.
                      • Jason4636
                        • 712
                        #131
                        I would get smaller tubing. But all my other fitting are large diameter. The inlets, esc's, and outlets are all large.
                        • Chrisg81983
                          • Jul 2011
                          • 1585
                          #132
                          Ahh I got u ..... what about bringing it down a size from esc to motors and out that large tubing steve sells will stretch over a golf ball if needed .
                          • Jason4636
                            • 712
                            #133
                            I'm going to go to lowes in the morning to see if the have a fitting to switch from the larger tubing to the smaller tubing needed for the motor cans
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              #134
                              Solder two pieces of brass together works too if needed as a patch for time being oh and I wrk at lowes lol I am the flooring sales specialist
                              • Jason4636
                                • 712
                                #135
                                I'm sure imm figure out something tomorrow. I'm wanting to test it out
