MADD CATT -41" fantasim saw build
  • Cooper
    • Jan 2011
    • 1137
    #346
    Uhh, in that video I think I had the 5018 3 blade stock cnc, polished, b/s. she really runs nice, I'll work on getting some video when water is flat. I ran 5218 also, I couldn't believe I had to lift the stingers about 1-1/2mm just between the 50 and 52 props, but it did also go airborne with that adjustment too. So maybe too much up. I did install a small air dam, just thought it was time to. I I remember right the 103 passes were with 5018s and I didn't get a mph on the 5218s, that's when she took off, well mph on that was 99, at least take off speed. And that was almost four min of full running. (Well not full but pass after pass).
    • keithbradley
      • 3663
      #347
      You're spinning them inward at this point, right?
      If you go to a lower lift prop like a 2 blade octura (I think you may have mentioned that?), expect to move the stingers down a bit. Those 5018 3 blade (and of course 5218 3 blade) create a lot of transom lift when turning inward.
      www.keithbradleyboats.com
      • Cooper
        • Jan 2011
        • 1137
        #348
        Yes they are going inward. And the octuras,,, well they are starting out as 457's. I'm working on a bunch of them. But the propshop has me looking everytime I get done with one. Lol,,,, a few more times out with the 52's to get some more data and ill start playing with them. Trying to figure out what she will be capable of pushing to the limits. Data is coming back as acceptable running in my eyes, spikes were just over 200 amps and settled below 150, motor temp was a little hot, and high rpms but showing room to push it :)
        • Cooper
          • Jan 2011
          • 1137
          #349
          Well, you're already faster than any IMPBA cat has ever gone prior to this year, so I would say you're definitely a competitor. The biggest hurdle is getting the water to make the run. If we can get calm water during the day, you can run, tune, and get the most out of your boat. If we end up with a 30 minute window at night like we did in the spring, you kind of just have to put a setup together and hold on.
          What props are you running in the vid (totally cool if you would rather keep that to yourself...just curious as I recall you saying 5018 FC, but they sound like 2 blades).
          Hey Keith, I was looking around on some guys saw boats, like cat power for sale. A modified front spoiler that was integrated into the hull. Would that be legal for competition? Not adding any length, running surface, ride pad, ect. Reason being I'm going to start getting into those two blade props and up the speed and I'm thinking of mounting some small simple blocks of aluminum with a slit into it on either side of inside forks. Then I could add different sections of say balsa or thin basswood at different lengths and angles. It a flip happens the wood breaks no big deal, hull integrity keeps intact spoiler breaks. I do have a piece of windshield wiper underneath as of now.
          • keithbradley
            • 3663
            #350
            I wouldn't think it would be an issue, but it's best to check the rulebook yourself and make sure. I took someone else's word a couple years ago and didn't get the record because of it.
            • Chrisg81983
              • Jul 2011
              • 1556
              #351
              Great job man she runs and sounds really good
              • Cooper
                • Jan 2011
                • 1137
                #352
                Thanks, ill try and get some videos during the first flat water runs. Had a talk with the film crew :)
                • Cooper
                  • Jan 2011
                  • 1137
                  #353
                  Forgot I had this video. First one is not good, it was first bit of testing on 8s. It was when the cooling line came off and killed the esc
                  And this one was the aftermath.
                  • rabosi
                    • Aug 2011
                    • 200
                    #354
                    Nice job man. I think that's the fastest Fantasm I've seen.
                    • angrycat
                      Record Chaser
                      • Mar 2013
                      • 66
                      #355
                      X2 man, im a fabricator/welder and the craftsmanship and attention to detail on this thing is staggering. i would definitely not have the patience or time to pull this off quite yet. also thanks for all the info on laying carbon/kevlar, im in the process of building a blackjack 29 hull with carbon/kevlar inlay and reinforcement because my seams split on the first hull. nice job man and those motors are sick
                      • Cooper
                        • Jan 2011
                        • 1137
                        #356
                        Thanks guys!! More to come!!! Soon.
                        • Chrisg81983
                          • Jul 2011
                          • 1556
                          #357
                          Hey buddy I had that happen to me once and boy I was pissed I killed set of schulzes that had about 1 other 30 second run on them
                          • miyage007
                            • 171
                            #358
                            What a great build mate. Keep it up and thank you for the inspiration.
                            Cheers,
                            Miyage007
                            From Down Under - Australia
                            • Cooper
                              • Jan 2011
                              • 1137
                              #359
                              Everything is looking good right now!! This is what I use for taping the garmen GPS down. It's a roll of carpet protector. Pretty stickey and flexible stuff, better than duct tape. I'm going for 110mph, don't know but gonna try.
                              • Cooper
                                • Jan 2011
                                • 1137
                                #360
                                Darn, was running just a little too wet. I dropped the stinger some because she was taking flight. Guess I put them down too much. Oh and lost a flex cable. I don't know why, but it might have been loaded up with seaweed. Came back in covered in it.
