Originally posted by h2o 1
View Post
37" Genesis Build
If you watch the video through to the end, you will find out what likely happens if you run a setup that extreme. The driveline self destructs and tears the boat up. That is 2 motors turning about 48,000 rpms on 6s, they are more appropriate for 4s.Originally posted by dddmx3 View PostWould if I go with the leopard 4082s instead? This video is so tempting... http://www.youtube.com/watch?v=sK_VYTokzLQMy private off road rc track
Ok. I figured the coupler or whatever was just loose. So you guys are saying my setup will be pretty fast? I've built rc brushless boats before just never fully understood the electronics part.After all is said and done, more is said than done.
Originally posted by h2o 1 View PostDefine Fast...When i started this hobby speed was everything! Once i got over 55 mph, i found myself paddling more to get my boat instead of driving it.Well I got my 32 inch cat to about 50. Maybe 60-70 mph with this one?Originally posted by jkr View PostHow fast you want to go?After all is said and done, more is said than done.
The 3665s.. With what kind of battery supply?Originally posted by jkr View PostHmm
You can spin a pair 45mm with Leo 3674 2650kv but probably a pair of 3665 2680kv will get you there.
You see it isn't only what motor to use...weight ratio is a big factor.After all is said and done, more is said than done.
I'll just go with the 3674 2650 on 4s. Wait.. It's technically called 4s2p right?Originally posted by jkr View Post4s or 3674 2650kv on 4s also
Just finished painting the hull today, will post some pictures after I reinforce the inside of the hull.After all is said and done, more is said than done.
4s 2p is only if you buy a 4s 2p battery. If you buy a 4s battery, you will not be running them in (2p) parallel as if you were running a single motor. To do so you would be running 4 battery packs which is way too heavy.Originally posted by dddmx3 View PostI'll just go with the 3674 2650 on 4s. Wait.. It's technically called 4s2p right?
I would assume that you will run a 4s battery PER MOTOR/ESC (or as mentioned above you could run a 4s 2p in one single battery pack) per motor. Beware though, you may not fit the 4s 2p packs in the hull - someone with a genesis twin will need to varify this as I have a genesis single and they wouldnt fit in the sponsons from my reckoning, however you may fit them as they will be positioned in the centre of the hull for your application.
Oh I was wrong. I figured the 2p standed for 2 packs or something. I will be running a 4s lipo to each esc. Sorry for the confusion.Originally posted by dogg View Post4s 2p is only if you buy a 4s 2p battery. If you buy a 4s battery, you will not be running them in (2p) parallel as if you were running a single motor. To do so you would be running 4 battery packs which is way too heavy.
I would assume that you will run a 4s battery PER MOTOR/ESCAfter all is said and done, more is said than done.
