Spirit of Texas Drag Hydro
  • Megabiker98
    • Jan 2013
    • 253
    #106
    Cool cool! Looking forward to see how this turns out!! I have yet to see one running at least on YouTube! Hahaha
    • Heaving Earth
      • 1877
      #107
      I believe turning performance is better with the blade behind the props.
        • 4297
        #108
        In front of prop I think to,
        Just need to set the rudder out of range of the props.
        But it looks ready to go, So test that baby.
        • Rumdog
          • 6453
          #109
          It'sost definitely going to turn better with the rudder behind the props.
          • drwayne
            • 2977
            #110
            +1 Fully agree steering is better with blade behind props.
            Perhaps I should have asked... "how bad is steering when in front?"
            Will start with blade behind, and try other at some later stage for personal enlightenment.
            Thx
            • Richie the shipwright
              boatbuilder
              • Dec 2012
              • 185
              #111
              How bout two smaller/shorter blades OUTSIDE props?? ...... same wet blade area would mean same drag? No? Still think rudder in aerated water wont bite as well....
              Im confused..... no...wait...mabee im not?
              • drwayne
                • 2977
                #112
                Richie, at speed the struts act as hydrofoils, so shortened rudder wont do, mate .. as now only 65mm below the stubshaft center..
                rudder would be out of water if I trimmed them up..
                That 65mm offers steering and waterpickups...
                blade before or after the props is a test I'll perform
                So today I spent time morphing the transom mount
                Now have
                option A, blade before props :. rudder pivot 32mm behind transom, with shorter pushrod assemblies.
                option B., blade after props : rudder pivot 100 behind transom( as pictured previously)
                Not a quick lakeside swap, but it's doable in ~60 mins
                W
                • egneg
                  • 4664
                  #113
                  Rudder behind the props. In front it will disturb one or the other prop when turning.
                  IMPBA 20481S D-12
                  • drwayne
                    • 2977
                    #114
                    rudder is about 15000 miles behind the props, hey Chuck !
                      • 7651
                      #115
                      Good point
                      • Megabiker98
                        • Jan 2013
                        • 253
                        #116
                        not necessarily! If the props are in a fixed position explain to me plz!!!
                        • Rumdog
                          • 6453
                          #117
                          OK. The rudder, when turned will divert, and disturb the flow of water toward one prop.
                          • Megabiker98
                            • Jan 2013
                            • 253
                            #118
                            alright that makes sense, then that prop that's getting the extra after will push? That makes sense! Haha
                            • egneg
                              • 4664
                              #119
                              Ok Doc ... props are done!
                              IMPBA 20481S D-12
                              • drwayne
                                • 2977
                                #120
                                The bloke making this hull and cowl has a liquification problem.
                                The North East coast of Australia is experiencing tornados and major heavy rainfall .. 600mm ( 24" ) of rainfall in 24hrs .. and more to arrive !
                                I rang this sodden fellow today, no power, no roads, water has them locked to their slightly higher than flood water property !
                                Poor bugger !
                                So I chose to create a temporary cowl... knowing his problems wont pass quickly.
                                So here is a temp jobby, just to keep the water out !
                                I used 2.5mm PET clear sheet, heated to formo ver the lumps and bumps, and voila' !
                                When the cowl arrives I will get serious about some scale appropriate decals...
