BBY PT SS45 build
    • 9481
    Right on Randy!
    I have this hull that needs finished...
    we might run this class this year..
    • RandyatBBY
      • 3943
      Right on Randy!
      Thanks, I have been hard at it fitted and built the stuffing tube one more solder to do the top oilier.
      Uploaded with ImageShack.us
      Randy
      BBY Racing
      • RandyatBBY
        • 3943
        Little more done, Installed Oilier and finished the seal of the stuffing tube.
        Randy
        BBY Racing
        • RandyatBBY
          • 3943
          Spending a little time in the shop to catch up after the holidays. Installed the custom bracket on the boat. Servo mount next.
          Randy
          BBY Racing
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            I like the rear motor mount. Simple, sound, and probably makes a good heat sink too.
            • RandyatBBY
              • 3943
              Always trying to be innovative. The tentative servo mount is a good place with the ESC, receiver pack and receiver on the right. Power cells in the front to make a great balance.
              Randy
              BBY Racing
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                Nice. I really like the slot in the motor mount. I'm sure you are plenty aware, but I would ensure that long distance pushrod is in tension when in a turn. I run a pretty long one in my smaller PT and it seems to work well.
                • RandyatBBY
                  • 3943
                  [ATTACH=CONFIG]91332[/ATTACH]
                  One of the good things about a push rod on the left..... it pulls in the turn and not push when turning right. Gotta see id a 40.161 will fit.
                  Randy
                  BBY Racing
                  • RandyatBBY
                    • 3943
                    Turn fin completed and installed.
                    Randy
                    BBY Racing
                    • longballlumber
                      • 3417
                      Hey Randy,
                      You may want to look at putting a brace across the engine well area to help ‘tie’ the deck together at or near the sponson transom area. At the speed we are throwing these PT SS45’s into the turns the hull is doing a lot of flexing trying to keep the fin hooked up.
                      Later,
                      Mike
                      • kevinpratt823
                        • Aug 2012
                        • 1462
                        Curious to see what is with the extra 2 tubes off the main stuffing tube......?
                        My private off road rc track
                        • RandyatBBY
                          • 3943
                          Water cool stuffing tube to keep the epoxy from getting soft.
                          Randy
                          BBY Racing
                          • kevinpratt823
                            • Aug 2012
                            • 1462
                            Nice! So it's a large diameter tube creating a sort of water jacket around the actual stuffing tube, and the oiler tube passes all the way through the jacket and solders to the stuffing tube?
                            Sorry, still semi-new to building, picking up all the info I can.
                            • RandyatBBY
                              • 3943
                              You got it! I do this on all 1/4 flex shafts and some High SAW 3/16 flex shaft with out Teflon liner.
                              Randy
                              BBY Racing
                              • RandyatBBY
                                • 3943
                                Canard wing installed two hours of cutting and fitting.
                                Randy
                                BBY Racing
