The drives in picture are set up as high as possible (towards surface). I might have been able to get them more parallel with the bottom of the hull if I'd mount them closer to the tunnel, but then I'd have got trouble positioning water intakes.
However, I came up with an idea which could bring the drives closer being parallel with bottom of the hull. First of all, I'd need to reinforce the hull from inside with cp-plate and gf-cloth, then carve or make a hole similar of the squarish part of the drive support and embed it in the hull so that only the cone shaped part of the support is coming out of the hull. This would lower the support by 2.5-3mm and it wuold be almost enough to get the drives in zero angle.
. sometime I wish I kept mine, they sure are cool to run and fit perfect in my little lake here.
Thanks also reminding me about the conductivity of the cf plate. That's something I've already learnt while browsing through the build threads here and I've already coated the parts of the cf plate with silicone which are under the pcb where the motor leads are connected. And just be be safe, I'll be coating the visible pcb and solderings of the esc with liquid tape.
