'69 Pay N' Pak Hook Tail Shovel nose 1/10th scale ML Boatworks build thread
  • JimClark
    • 5913
    I would use 1/32 ply on the deck. I used 1/32 on the top and bottom on mine and it worked out great. You can also soak the wood to help shape it before you glue it down.
    Billy Graham
    • cybercrxt
      • 2926
      TC, unfortunately i have never used a wire drive and just dont know anything about them, or even what is needed to make one work. Jim, no 1/32" for me! I cannot stand the stuff. It causes to many waves and is much to fragile unless glass is added overtop of it, and if I am doing all that i might as well use 1/16"! Oh, went ahead and ordered a castle ice 100 controller, should work great with the scorpion 3226-1600kv!I got more sone last night. Made a really nice removable hatch where the dummy motor goes. I am contemplating making a mold and making one out of glass, just have not decided yet if its worthwhile. I will load pics later today. Mike
      • monojeff
        • Nov 2010
        • 2728
        Nice mike ill follow the build on here also.
        Like I said in our conversation yesterday and for others.
        Some of us out here run 450/3 blades on the proboat motors and they have no problem with them.
        The scorpion will push it no problem.
        447 is a great place to start but I have no doubt it will handle a lot more prop.
        Keep up the great work!
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • cybercrxt
          • 2926
          Thanks Jeff, sounds like I have a starting point!
          Got more done this weekend. Here are the pics. As you can see, got the dummy motor inset tray built, rear hatch built with the complex curve! Had to soak the ply and shape from there. Carbon Veil installed and interior epoxied. Its starting to look good! Mike
          • cybercrxt
            • 2926
            Interior epoxied. Moving along now! Mike
            • cybercrxt
              • 2926
              I got some cool stuff in the mail yesterday. Got my cowling, dashboard, steering wheel, misc cockpit parts, and a cool rudder he had that is about the nicest I have seen for a boat this size from Mark at RMHydroplanes.com. I also received my Castle Ice 100 esc, and Scorpion HK3226-1600kv motor. So now I have the majority of what I need to move forward with the build. As you can see, I went right to modifying, and fitting the cowling. I decided, with the way this boat is built, that I will make the rear hatch held on with neodymium magnets and keep it a semi "wet well" as nothing will be in there of any significance . I plan on having the electronics all in pockets in the forward cabin, and that will be a tape down hatch. This shovel nose has so much room its amazing compared to pickle fork hydros! Anyways, I am pretty happy with things so far. This boat is not going to be used in a NAMBA race event, so I am overbuilding it, and making it a solid, long lasting boat. This is why I went with a motor slightly larger than allowed to push the possible extra weight I may end up with, but honestly, its still very light, and I suspect it will not be more than 6 or so lbs, which is a significant change vs. the 16lb FE 1/8th scales I am use to! More to come real soon!
              • cybercrxt
                • 2926
                • cybercrxt
                  • 2926
                  Got the rear top deck sides on last night. Still have to trim the edges. Mike
                  • cybercrxt
                    • 2926
                    Not as many pics as I wanted to do, but here is the current status of the build. Got the hull pretty much finished up, other than hardware and paint. I have the decks all on, sanded clean. Current weight on the hull with cowl and hatch is around 6lbs. This includes all 1/16" decking, one layer of 2oz cloth on the top deck for added long term strength...so its built to last! Due to that, I figured up with the scorpion, esc, hardware and paint, its going to push 7.5lbs..maybe more. Due to that, I figured up the scorpion is not going to be enough to push this to 50mph, so I decided to scratch that idea. I am not racing this, and weight was never something I was worrying about as I knew I could use what I wanted for power and have fun...so, with that in mind, I have a 1521 1y 1577kv motor and hydra 240esc I am going to use paired up with (2) 4s Hyperion 3300mah, 45c packs for a 6600mah setup. Ordered a Hitec waterproof digital servo and some driveline hardware when OSE opened up yesterday, so maybe I will get that stuff by saturday. Also picked up the Light Persimmon Metalic dupont basecolor as well. I know a 1521 is overkill, but I can prop it down, and have a very cool running setup with an 8lb rtr hull! Enjoy the pics, Mike
                    OH, and you will also notice I did away with the drop in tray for the motor hatch cover. I did what I think is a lot cleaner looking setup, and more realistic looking inset with flat epoxy glass hatch..
                    • cybercrxt
                      • 2926
                      and the motor...
                      • studioRS
                        • Jan 2009
                        • 116
                        Such a kewl build, I like the fact it is going to be overpowered! Could you please share more details on the painting aspects of this? Like primer used, paint, etc? Thanks.
                        Glad I subscribed to your thread, planning to build a 1/10 Gary Finlay 1954 Jones "Lake Tahoe Yacht Club, Breathless U-22" and inspired by your set up.
                        I used to work for Marine Specialties way back in 1976, RC boats go deep in my roots.
                        Cheers, Thompson
                        1/10 1954 Breathless U-22, Tahoe Yacht Club | 1/16 1958 Dumas Thiftway Too, built in '92
                        • studioRS
                          • Jan 2009
                          • 116
                          Oh, just for kicks I think I'll run an old Marine Specialties rudder. Might not be the latest gear, but they still are nice to this day.
                          Just a Q on sealing the birch plywood...
                          Could water based Minwax Polycrylic have been used to seal the ply instead of epoxy? I know epoxy is stout and really does the job and also acts as an adhesive for all joints.
                          Cheers, Thompson
                          • cybercrxt
                            • 2926
                            Sorry for the late reply. I have put the build on hold till I finished up my storage shed, and didn't realize you had posted. I would use epoxy not minwax. Epoxy adds the strength you need. I will be painting the hull soon and will work on the details for that soon as well. I am using Dupont Nason products....2k Urethane primer, nason basecoat, and nason 496-00 panel clear coat. Talk soon, Mike
                              Just poking my head in here,but I just love the cockpit gauges and wheel.
                              • cybercrxt
                                • 2926
                                Here is a pic of the same dash in my 1/8th scale U-64 Squire Shop Build. Its a pretty good fit on 1/10th and 1/8th scale setups I think! Mike
