does anyone have any tips on how to sharpen, balance, and polish a prop.. i found a 4 part series on you tube and got a prob balancer.. does anyone have any extra tips that i might need to know?
21 inch bby oval racer build
Caution when working with Beryllium Cooper! Activities such as grinding, sanding, polishing or any activity which abrades the surface will cause airborne dust particles. These Beryllium Cooper particles are highly toxic! There are dangers involved with inhaling dust or fumes. It can cause serious, chronic lung disease in some individuals. Over time lung disease can be fatal! Warning- Potential Cancer hazard!
http://www.offshoreelectrics.com/inf...andbalance.php
http://forums.offshoreelectrics.com/...t=balance+propLast edited by ReddyWatts; 06-09-2008, 06:52 AM.ReddyWatts fleet photo
I do, there has not be any documented cases of cancer or lung disease from this in 25 years, just be aware of the hazards and be careful.ReddyWatts fleet photo
and also.. does it exactly have to be as sharp as a blade.. cuz im trying my hardest and cant get it as thin as that.. like in that post that said the prop cut his hand.. i cant even make it cut paper.. i have been hard at work on it for like 45 min
None of mine will cut paper, but they could cut skin when holding them while removing the prop nut.ReddyWatts fleet photo
Yes, it uses all of the blade during the run.ReddyWatts fleet photo
i got the electric stuff layed out
12x2 orion revolution
novak dually esc
venom 4600 6 cell- not the best but will work for the time being
and probably a spectrum reciever
then i made a cooling coil becuase i was low on money and the outlet
i also changed the tubing to high flow tubing
