micro servo question
  • vdubsport
    • 42
    Hi new to this forum,
    Has any one every tried using a micro servo on a outoutboard , reason asking is i have just built scratch mono and a reagular servo stading up is to tall for the boat. Witch leads to my second question if i lay the servo sideways it fits well can I only run one linkage on a outboard. Here are some pics.
  • vdubsport
    • 42
    i have made a radio box that fits between the rear strut and the battrie tray in the front other wise i would put the sevro their. any help or input would be great thanks
      You can run a standard servo on its side, and run a single pushrod to the motor - IF the pushrod is straight and heavy. Otherwise the rod will flex. I used to do this on an OB tunnel years ago.
      • vdubsport
        • 42
        Cool thanks the guy at my lhs said the mirco would work but it sounded to small and i was worried that is would strip out, im glad that i didnt wast the time making mounts only to find out what would happen thank you again
