Hi there
I want to build a 6'-0 long scale model of a cruser. It is a semi displacement hull nd my model should weght about 66 lbs.
From inquirires made to date, I know I shoud be using twin 12V 700 or 800 motors. Since I want single prop, I will also be using gear box. If I go true to scale on prop, I would be looking at a 3" to 3 1/2" prop.
I have been searching hobby shops on line and found props s in this range, but some have 1/4" shaft and others have 3/16" shaft. The thing is, most place only lists up to 3/16" shaft.
Since I am going elctric and not looking for high speeds, would 3/16 " shaft be good?
I am also looking at posibly a 2 1/2" 3 of 4 blade prop. Woulds this size push my boat"
I would appeciate any hlp you can give me.
Michel
Michel
