any links on the loctite or Permatex High Strength Sleeve Retainer?
my brushless super hawaii project
The loctite can be found here in the OSE store
http://www.offshoreelectrics.com/pro...prod=mc-loc603
And for the Permatex, i used google.
Z
KBB34" Mono - Fast
ToySport Triton- Not as fast
Maybe right now it will be cheaper.
But what are you going to do when you need a new flex cable and prop shaft?
Are you just going to buy another new assembled one?
If you buy the loctite now and do it your self this time,
you wont be buying an assembled flex cable next time.
You will have the loctite ready for the new flex cable and prop shaftZ
KBB34" Mono - Fast
Yes you could buy it already assembled, But then you would not have the loctite Or if you buy it assembled and cut the piece off you would need the loctite to use the other half of the flex cable some other time. You could use the loctite for other things as well including loctiteing other screws or parts.
If you buy it assembled you will wish you assembled it yourself, If you assemble it yourself you are going to wish you bought it assembled (murphy's Law)
Good luck on your decision !!!
ok i was thinking of puting the motor in the middle compartment now.first of is the flex cable thick enough to use at that lenght without bending.second how will i waterproof that area that i need to cut the hole in order to do that .here is a pic the arrow is pointing to the hole im gonna have to cut out.please help i got no clue
just a kid with a super hawaii project
the flex cable is in a teflon liner and then you put it in a brass pipe. So it can't really go anywhere. Just use epoxy to waterproof the outlet.
here's some old construction photos that I've got.BOATS CAN FLY AND SHOULD!
ok guys this is what im getting tell me if i need to change something.
bj rudder http://forums.offshoreelectrics.com/...ead.php?t=3603
locktite 603 http://www.offshoreelectrics.com/pro...prod=mc-loc603
speedmaster stinger 3/16 http://www.offshoreelectrics.com/pro...os-stinger-str
octura.150 flex shaft unasembled http://www.offshoreelectrics.com/pro...oct-oc150L-24c
2 ep 4500 7cell stick packs http://www.offshoreelectrics.com/pro...d=ep4500-7cell
feigao 540XL brushless motor -9XL http://www.offshoreelectrics.com/pro...prod=fei-540XL
fiegao 540 water jacket http://www.offshoreelectrics.com/pro...mjacket&cat=42
xpower brushless 100amp esc http://www.offshoreelectrics.com/pro...od=xpo-blb100a
brass bullet nut octura 3/16 http://www.offshoreelectrics.com/pro...od=oct-oc6pnmm
a variety of props to testLast edited by eclipse; 06-15-2008, 11:51 AM.just a kid with a super hawaii project
