HPR115 Bulletproof Build
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1837
    #151
    A couple more...
    • worriedsick4u
      • 693
      #152
      And she found her new home in Florida. Should have her dialed in tomorrow. Will post speeds and set ups. Beautiful boat my friend. Thank you.
      • ManuelW
        • Oct 2010
        • 743
        #153
        Will be waiting for speeds too, to add them to the HPR speedlist, already got the pics from Kent!
        Enjoy it, its a really awesome boat and lets call it "capable setup"!
        regards,
        Manuel
        • worriedsick4u
          • 693
          #154
          First dialed in run. With 7S 5000mAh (heavy lipos) and 447"s in wye she ran 85.6. Nothing heated up over 100.5*. Everything stayed cool. Gonna run 8S tomorrow 2X4S 4000mah. After tomorrow will try 5S delta. Manuel or Kent, should I try 450/3 tomorrow on 8S?
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #155
            I don't think you will win a lot of speed with those props, as the total pitch is not far off from the 447's. They may benefit a heavier boat where slip is more of an issue. I would definitely stick to the 447's on 8s, but for high speed switch to delta and give it a try on 5s. Not worth loading the up the system with those 450/3's. something with a smaller diameter and more pitch might do the trick if you want to run on 8s maybe a set of 4518/3 or 4516/3. Could also work with a set of cut down 57's to 48-50mm but maybe only for short runs. Just on a side note. Your 2250's in the HPR has pushed the MHZ138 to 87mph with a set of 448cnc on 8s. No drama there!
            • Pheyd
              • Sep 2014
              • 79
              #156
              That is absolutely gorgeous! I'd love to have you build me a boat like that some day :)
              • thomaslambo
                • Nov 2010
                • 232
                #157
                My compliments, a beautiful build.
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #158
                  Thanks for the compliments, anytime you want to look into a boat let me know :-) and we can work something out. If you haven't seen, look up the MHZ 185 Tag Heuer and the johnnie Walker tribute. They are more resent builds.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    #159
                    Thanks Thomas, always nice to hear good feed back :-)
