Fightercat Fantasm 41" single drive
  • Tbauer
    • Aug 2012
    • 300
    Finally finished my Fightercat Fantasm 41" and Wow, what an AWESOME HULL !!!!!!! I can't say enough about it, I mean it has excellent handling and is very efficient.......... I run 6s, 2 x 3s Turnigy Nano-techs with the Leopard 4092 1480kv, Turnigy Aquastar 240v ESC and an Octura 447/3. With that set up I hit low 60's. Thats pretty darn good for a 41" on a single setup. "Hello Kitty", props to your set up, thanks for the information!!!!!!
    I also made an easy mounting/removalIMG_20121007_191024.jpgIMG_20121007_175908.jpgIMG_20121008_181528.jpgIMG_20121009_195932.jpgIMG_20121012_225827.jpg system for those that are low budget like me. I can remove the entire motor, esc, and receiver by 6 screws. Its all attached to an aluminum L bracket that is attached to the hull. I take it out and place it in my other boat, it's very convenient and simple.
  • Tbauer
    • Aug 2012
    • 300
    IMG_20121026_224916.jpgIMG_20121028_010318.jpgIMG_20121031_052155.jpgIMG_20121031_052224.jpgIMG_20121028_202005.jpg
    • Tbauer
      • Aug 2012
      • 300
      IMG_20121011_130456.jpgIMG_20121008_221036.jpgIMG_20121009_200612.jpgIMG_20121008_181547.jpg
      • Tbauer
        • Aug 2012
        • 300
        • Rocstar
          Joel Mertz
          • 1536
          Cool Man!
          • kevinpratt823
            • Aug 2012
            • 1462
            Sharp! Nice work.
            My private off road rc track
            • Tbauer
              • Aug 2012
              • 300
              Thanks guys, appreciate it!!
              • Rumdog
                • 6667
                Looks great!
                Am I seeing Dean's plugs?
                • Tbauer
                  • Aug 2012
                  • 300
                  Ya, why, do they suck? I haven't had any problems
                  • Rumdog
                    • 6667
                    For your setup... Yeah. Pretty inadequate. Go with 5.5mm bullets. Deans are only good to about 60 amps.
                    • Tbauer
                      • Aug 2012
                      • 300
                      Did not know that, thanks for the heads up, I am a trial by error learner..... short bus.....lol
                      I will definitely trade up
                      • Tbauer
                        • Aug 2012
                        • 300
                        Do I have to replace them off the batteries too or just off ESC? Am I looking am some serious solder time now? LoL changing batts up across the board and charger? dammnnnnn
                        • shrive81
                          • May 2012
                          • 64
                          i am thinking of purchasing the same hull, can you explan the process for painting the hull aka did you have to sand and what grit then what type of paint did you use and did you use a clear at the end? Your boat came out amazing!!!!
                          • Rumdog
                            • 6667
                            Unfortunately, yes ditch all of the deans. They are creating a bottleneck.
                            • shrive81
                              • May 2012
                              • 64
