My attempt at building the Mean Machine
  • dana
    • Mar 2010
    • 3570
    #46
    Looks good man. I had no problems with the tactic. Also you might leave the long rudder, it helps keep it from hooking in the turns. Which rudder is it?
      • 5660
      #47
      Thanks Dana!
      I am glad the Tactic has no problem, my rudder is this: http://www.offshoreelectrics.com/pro...=ros-21-rudder, when you say "hooking" do you mean the transom takes a dive or the bow dives? I am a bit foggy with the meaning of "hooking".
      Did you use the same rudder and if yes, did you cut it down? I am just afraid the length will increase the chance of hitting some drift wood or turtle.
      • dana
        • Mar 2010
        • 3570
        #48
        I mean it can spin out in the turns. I cut mine down, and every now and then it hooks. Nothing bad. I have the same rudder you do. In hind sight I would have left it long or cut a bit less off it
          • 5660
          #49
          Thanks for the heads-up, I always thought too much rudder causes spin-outs.
          • KartRacer
            • Aug 2012
            • 355
            #50
            Tlandauer
            The long rudder works great on my DF Pirate, but I did catch a rock under water and had some minor damage. Hoping to get it back in the lake Saturday.
            Water levels in my area are extremely low, need rain badly. I had an area dug out in the lake shore to provide a launch area so I don't have to walk out in the water to get deep enough for rudder clearance.
            If we get some rain, ok a bunch of rain then lake levels will return to normal and problems go away. Until then I have to stay clear of the shore line by 20 feet!
            KartRacer ~ Dennis B
            Delta Force Pirate 35'~Leopard 4092~1480Kv~Seaking 180~2X6S 65C 5000 Mha Dynogy Lipo,Parallel
            • dana
              • Mar 2010
              • 3570
              #51
              If you do cut, only take an inch off
