MG rebuild, repower, and paint.
    I get one around the front at the lens rim,
    And one around the body at the back with the door open.
    And then you can lay the door down on the strap and the camcorder will go off,
    Just open the lens first and then mount it.
    It will get easier the more you do it to.
    • Flawlessdecisions1
      • Jan 2013
      • 73
      Where did u buy ur off set rudder?
      • Jason4636
        • 712
        Kintec is where I got it
          • Jan 2013
          • 73
          Any specific one? Sorry new to this ! Lol
          • Jason4636
            • 712
            #35
            I got the second one on the page
            They didn't have the top one when I got mine. I guess its your choice
              • Jan 2013
              • 73
              #36
              Thx a million!
                Ok now where on good turf,
                I think look good, But may look better with out the loom.
                Just black line, Also you will not see the grease on it from the flex.
                How does it run for you as far as straight runs and the bounce or up and down rpm ?
                And what props work best for you so far ?
                • Jason4636
                  • 712
                  #38
                  I only ran the boat thru 2sets of packs after the rebuild. I'm running a x642, it would hop some when it was accelerating. But about half way to top speed the bounce almost went away. Within those 2 runs I hit 52mph. I know there's more in it.
                  Setup, SW-180, Leo 4074 2200kv, 4s2p nano 65c 5000mha, prop x642, strut bottom is level with the sponson bottoms, 0 angle in the strut, batteries right at 30%. I think I might get next weekend off. If I do I'll try that video camera, velcro to the tx
                    Yes, I think you will like that video rig.
                    The setup in mine is sw-180,keda 4074 2364kv, 4s -150 flex.
                    I ran two sets of pack on it so far, 2 - 4s packs and 2- 2s packs on a x642.
                    It ran pretty good with strut at 1/16 above the sponson and +2 on angle of the strut,
                    But it was loose and had a little bit bounce or sea sawing to it.
                    I will try 0 angle on strut next and then level with sponson to,
                    Than some m and p props to.
                    No video and no gps those runs.
                    I was thinking of trying some of the M and prather props,
                    To see if they help any with the up and down of the rpm that I hear all the time on a lot of these boats,
                    It is like they air out or something like that and the motor sound go's up and then down.
