Zonda gets a face lift.
This topic is closed.
  • twissted
    • 867
    #76
    • twissted
      • 867
      #77
      I have 2 TP-Power 4050 2220 kv motors that will be pushing 1945/2 counter rotating props on 6s. should get me over 100 mph! I also have other props to try but I'm starting here.
      • straitline
        • Dec 2012
        • 158
        #78
        Twissted loved all the zonda info. Just one question..In which direction do you have your props rotating. I'm trying to figure that out before I put my zonda in the water this weekend. Which iis best?
        • twissted
          • 867
          #79
          I have them turning in.
          • twissted
            • 867
            #80
            The TP 4050 came in today! wo hoo!
            • twissted
              • 867
              #81
              These Octura X447 props or worked over by your truly and i hope that they work well with the tp4050 motors.
              • twissted
                • 867
                #82
                Here is the test start of the motors. and to see if the props are pushing air.
                • twissted
                  • 867
                  #83
                  • bracka69
                    • 298
                    #84
                    Originally posted by twissted View Post
                    The HK 180 esc are a great esc! I would push them or the sea king as they are the same. I do want to learn how to get them to run on 8s. I have read that it is possible.
                    I've heard if you disable the LVC you can run them on a higher cell count than 6s.
                    • twissted
                      • 867
                      #85
                      I will not have to go to 8s with theses motors. The tp4050 2220kv is designed to run on 6s! I got the lipos charged and will give it a go tomorrow in some calm water. I'm hoping that it spooky fast!
                      • straitline
                        • Dec 2012
                        • 158
                        #86
                        Zonda owners have any of you had a problem with the upgraded rudder that come with the Zonda. We have three down here and all of them the rudder does not pick up water. Have anyone else had this issue? What was the solution?
                        • twissted
                          • 867
                          #87
                          I did something that yo may want to look at. I drilled holes in the hull and got water in that way. It's simple and very low cost.
                          As you can see I added a 150mm push/pull rudder that is not bolted in but is in place in these pictures. I used epoxy 3 different times to build up the base to make sure the pickup tube if not going to break or move. I used a dremel to shape the hull and the tube that sticks out when the epoxy dried. You will want to run the tube down flush to the bottom so that the back side protects the hull and also flows good.
                          • twissted
                            • 867
                            #88
                            I also beefed up the rudder plate of the hull with a saddle mount.
                            I used 2mm on the base using marine epoxy and 4mm on the sides also with marine epoxy to lock int the rudder base.
                            • twissted
                              • 867
                              #89
                              I ordered so bad ass Lipos for the boat and my 1/5 brushless truck build to day.
                              Apr 26, 2014 00:45:11 PDT
                              Transaction ID:
                              Hello Are Vee In A Fix,
                              You sent a payment of $407.20 USD to Superior Matching Concept, Inc.. (danny@smc-racing.com)
                              It may take a few moments for this transaction to appear in your account.
                              Merchant
                              540-298-7706 Instructions to merchant
                              You haven't entered any instructions.
                              Shipping address - confirmed
                              Are Vee In A Fix
                              731 Index St.
                              Omak, WA 98441
                              United States
                              Shipping details
                              The seller hasn’t provided any shipping details yet.
                              Description Unit price Qty Amount
                              Race Formula 14.8V 6500mAh 70C
                              Item# 6570-4S2P $84.95 USD 2 $169.90 USD
                              Race Formula 11.1V 6500mAh 70C Traxxas
                              Item# 6570-3S2PT $54.95 USD 4 $219.80 USD
                              Shipping, Handling, Discounts & Taxes
                              $17.50 USD 1 $17.50 USD
                              Subtotal $407.20 USD
                              Total $407.20 USD
                              Payment $407.20 USD
                              • twissted
                                • 867
                                #90
                                SMC Race lipos.jpgI'm going to run the 3s in series to get 6s!
                                Theses are the best lipos you can buy for the money!!!
