FighterCat Cheetah build
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    I was commissioned to build a single-motor Cheetah for Cameron, who wanted to stay with a sport setup with decent speed and runtime on 4S2P. I advised him to have Keith build it for him; Keith's builds are impeccable, but Cameron lives nearby and wanted me to do it. With the bar set so high by KB, I set out to build a boat that measures up. After researching other Cheetah builds, most of which were 6S singles and twins, I came up with a single motor power package that can deliver speeds around 50 mph without too much current draw. A Leo 4082 2000KV motor and the trusty T-180 spinning a 447/3 was decided upon.
    One thing I learned from conversations with Keith and some of his Cheetah guys was that the tall transom needed a long strut to allow adequate adjustability. The commonly used TFL struts needed to have the mounting foot placed low on the transom, which made nutting the bolts inside tricky, clearance-wise. As a firm believer in HD hardware, I chose a Speedmaster skeg strut and 60/90 rudder, both needing some modding.
    First off, I reinforced the inner transom to keep things strong
  • properchopper
    • 7708
    Cheetah build
    The Spd strut was for a .250 shaft, so I had to convert it to .187. Hmmm...
    First I pushed in .250 L/T bushings
    Then made a carrier for the final bushing
    Now a standard Speedmaster .187 bushing slides right in
    Stepped down the nose for the stuffing tube
    • properchopper
      • 7708
      Cheetah build
      Moved the strut inboard so drive dog/front of rudder line up, trimmed and rounded rudder bottom, and installed servo rod pass-through tube - I like to give the servo rod plenty of room to articulate without rubbing.
      • properchopper
        • 7708
        One of the most essential considerations in determining component location is to first determine how this effects CG. Here is my rule of thumb :
        After mocking up the insides
        I use my extremely high-tech CG-Balance-O-Meter to see where I'm at
        I can then mark the motor mount location, do the strut ( I used a teflon lined tube) and seal the bottom
        • properchopper
          • 7708
          Cheetah build
          I'm not a big fan of velcroing down the speedy. The speedy gets hot, loosens the adhesive & the esc moves around. Made a bed for the esc and shortened some bolts to use the tabs on the esc:
          To firmly glue down the battery trays inside the stepped sponsons I had to make some spacers (like trying to glue a 2 X 4 to a staircase)
          To keep the cooling lines nice and neat, I hand-made some CF holders
          Keeps the interior neat looking
          • properchopper
            • 7708
            Cheetah build
            Hatch retention : pinned front with 4mm stainless rod
            Rear uses anodized thumbscrews through grommets mating with nylon inserts. Simple, clean, strong and waterproof unlike the "twist n' locks" which are tricky to waterproof
            • properchopper
              • 7708
              Cheetah build
              A few more details -
              Made a parallel adaptor using 8mm female for splice; soldered on to esc eliminating one slip-joint for better heat/resistance management
              Trick dual water outlets
              • SirBudman32
                • Aug 2011
                • 701
                Going to be doing one of these over the winter. I seen your write up on another forums page and gave me some go ideas for my build. One question I do have for you is I see that you used a SKEG type strut on this build, what is the reason for this as I have a regular type strut?
                Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                • properchopper
                  • 7708
                  A few graphics brighten things up.
                  A lot more "little details" went in to this build - maybe too boring to post. In all, this boat is one beaut; I'm strongly considering one for myself for some P-Offshore action.
                  Thanks for looking & feel free to "borrow" any ideas you'd like - We're all in this together
                  Tony
                  rcboatbuild@hotmail.com
                  • properchopper
                    • 7708
                    In theory a skeg strut will hold the boat to a tighter line in high speed turns.
                    • SirBudman32
                      • Aug 2011
                      • 701
                      Ok thanks. Really looking forwards to the build as it will be my First. If I run into any problems I guess I know who to ask.
                      • properchopper
                        • 7708
                        I'll be there for you, Bro
                        • LOVE6S
                          • May 2012
                          • 538
                          [ATTACH=CONFIG]84979[/ATTACH] [ATTACH=CONFIG]84978[/ATTACH]
                          [ATTACH=CONFIG]84980[/ATTACH]
                          What are the water outlets from, is it just a thru the hull conn, cut down, looks nice, good flow too I bet.
                          • properchopper
                            • 7708
                            Darn, my secret's out
                              • 9481
                              I like the 8mm idea, and I thought about that for my SF240's
                              on my PMono I soldered the second pair of battery wires on the underside of my T180 escs
                              works great and no heat what so ever
