Rebuilding a wrecked Genisis
  • Tbauer
    • Aug 2012
    • 261
    While running 6 cells with the stock 2075kv motor and a 120a esc, boat hit a roller, landed nose down and torpedoed straight down to the bottom. The water was approx 6.5' deep.
    This is my first attempt at such serious repair work. I am very happy with the outcome..... Not that I want to do it again, but I learned along the way and would be able to improve it even more. Thanks for letting me post......
    • 7651
    Great work Tbauer,I ripped the back off my Geico and that started all kinds of FG repair/changes.That turned out real nice,you can't even tell it was wiped.
      • 5660
      Can I take lessons from you two? I did some on my shipping damaged DF 45 Sniper, and also on my MG. But they are no where as major as you guys'. And they are visible!
      Great job!
      • Tbauer
        • Aug 2012
        • 261
        Thanks, I appreciate that...... I must say that I wouldn't be a very good mentor tho, all of my experience came from O.J.T.!!! LoL
        Believe me, I certainly learn the hard way more often than not
        • bruceisla
          • Aug 2012
          • 53
          I like the blue!! What is the color and manufacturer?
          Thanks, Bruce
          • Tbauer
            • Aug 2012
            • 261
            Its Electric Blue by PPG
            • stadiumyamaha
              • 1284
              Nice fix man. That thing was piled up good.
              • Tbauer
                • Aug 2012
                • 261
                Born Again
                Finally got her wet then downloaded a couple pics. I was equally happy with the speed on choppy water as I was with the repair...... Solid vessel........
                • Tbauer
                  • Aug 2012
                  • 261
                  I didn't figure out how to post the video on here
                  • Jersey Crewmax
                    • 443
                    The boat looks great, really liking the blue.
                    • Tbauer
                      • Aug 2012
                      • 261
                      Thanks, the color turned out better than I planned, Electric Blue from PPG
                      • jlr3rd1
                        • 240
                        i was looking at your dual cooling lines :) how did you affix tube to the rudder??? and also does the flow the water good ??? thks jim
                        2 SV27s, 1 SV27r, 2 BLACKJACKS 26, 1 GENESIS 40
                        • Tbauer
                          • Aug 2012
                          • 261
                          Actually it works really well. I couldn't find a dual pickup in that size without having to purchase the whole setup so I made my own. I just used an old piece of junk controllers expandable antenna. I broke it down to the right size, which was the third one down from the top on my old Traxxas. Now the trick was using the right glue. I initially used the metal weld glues (JB weld types) which didn't hold up. Then I used super glues (Gorilla, Super Gels etc). They sucked worse...LoL The right combo turned out to be Epoxy. But not just any like a 5 min etc...... You gotta use MARINE EPOXY, the white kind. It has held since both major wrecks. Just tape off the side edges of the rudder, exposing just the flat back side where you want to attach it. After you attach it, just tape it in place overnight. Make sure it wont move, like slide down or anything cause that marine epoxy is seriously good stuff. After it dries your golden. I run a single line to my motor and the other to the ESC. It doesn't hurt to keep everything as cool as possible. I mean why run warm water halfway through when you don't have too right? Take care, it's a simple and inexpensive way to keep your electronics even cooler....... Hope it helps ya too!!!!!
                          • Tbauer
                            • Aug 2012
                            • 261
                            I forgot to mention at the 430 mark it does a pretty good 360 degree spinner...... Gotta love the GoPro
                            • jlr3rd1
                              • 240
                              thanks i think i will be doing the same on my boat :) thks again for fast response jim
