"Double Tap" Twin Screw 41'' Fantasm
  • Make-a-Wake
    FE Rules!
    • 6057
    I'm a fan of big, long rudders with dual pickups
    I get rudders longer than usual, and if they dont work out, then I lop some off, you cant add!! I've only cut two down so far out of 20+ boats, i like 'em long, great control that way in my opinion. I race my Pursuit so its just average length where you need all the help you can get.
    • keithbradley
      • 3671
      you cant add.
      I beg to differ sir...
      www.keithbradleyboats.com
      • Make-a-Wake
        FE Rules!
        • 6057
        OK, fill me in...........
        • woodster
          • Feb 2011
          • 433
          Im diggin the dual pickups. Very nice
          • keithbradley
            • 3671
            Just busting your chops.
            I've made them longer before just by TIG welding aluminum bar to them and then finishing them off to the correct shap/size. I realize most people don't have the ability to do that though. Cutting them off is far easier!
            • Rocstar
              Joel Mertz
              • 1536
              Installed some hatch bolts...
              • Rocstar
                Joel Mertz
                • 1536
                ESC Mount...
                • Rocstar
                  Joel Mertz
                  • 1536
                  Shoehorned in...
                  • Cooper
                    • 1168
                    Looks good so far. Im watching and keeping notes as im planning similar build over winter. Might go cf hull but same motor setup. When you run those on 8s what are you realistically trying for top speed?
                    • Make-a-Wake
                      FE Rules!
                      • 6057
                      Looks good...........................you may have a 70 mph boat on your hands.
                      • Rocstar
                        Joel Mertz
                        • 1536
                        Motor mounts and tubes in...
                        Simple paint. Nothing special..
                        • Rocstar
                          Joel Mertz
                          • 1536
                          Ready for testing...
                            That controller looks so good in there I may have to get me a Fantasm.I'm sure my 950kv TP's would do it.
                            • RCKong
                              • Sep 2009
                              • 1680
                              what props you got on there ? with two of those torque monsters in the boat you will be able to spin some hefty props... also did you run the bolts for holding down the ESC thru the tunnel ? Looks good... and the dual pickup rudder is the way to go as far as I'm concerned. I've yet to see in hull pickups spray out water like these do.
                              Looking forward to seeing it run
                              • Rocstar
                                Joel Mertz
                                • 1536
                                I have a set of Prop Shop 4518's and 5017's, we'll see how she does...the ESC mount is bolted to another CF plate that is epoxied in place.
