Vac-U-Pickle w/SV power vid
  • Doug Smock
    • 5264
    Here is a vid of some testing I did last weekend.
    Unpainted prototype with Fullers hadrware, SV power package on 4s 4900s with a M645.
    I want to try a cupped 645 to try to reduce some of the hop.(strut is all the way up) I think I may be missing the weight of the rec. pack at the transom. Then again it may be ok, the lake was a pretty rough.
    After 7+ laps the motor was the warmest thing in the boat at 125'F. Cells took 2800ma .
    That is a 20 size mono I'm playing with out there.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  • SJFE
    • 4735
    Shes a runner Doug. Sounds like it had about 5 laps left in it. Nice setup.
    • flyboy320
      • Mar 2008
      • 88
      Same setup as I'm building now. SV27 power, CC Barracuda 80amp ESC, 4500mah 4S lipo's, Fullers h/w. So far looks great and hope to get her wet next week... :)
      • Raydee
        • 1603
        It's about time
        THat looks like the setup I will run for sure.
        Team Liquid Dash
        • Doug Smock
          • 5264
          Originally posted by Raydee View Post
          It's about time
          Well excuuuuuse meeeeee!!! I had some computer issues this week.
          Next weekend I'll be testing a 1509 1Y on 2s2p in the same boat. I'll post a vid on this thread.
          Thanks Tom!!!
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Jeepers
            • May 2007
            • 1973
            Doug, I think you may have a serious problem with your hydro. It has a really really bad buzzing sound coming from some where behind your transom you may need to have it checked out!
            • Jeepers
              • May 2007
              • 1973
              Here is a video of our SSH class Doug.
              • Doug Smock
                • 5264
                Thanks Jeepers, cool video, nice pond!!!
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • 10gauge
                  • 281
                  Great run D.Smock! Any pix of from the inside? The Neu 1509 should launch this boat in orbit! Good Luck!
                  Mean Machine Cat: 9XL, 4S2P, CC120, M545 (50mph) -- DF22 Hydro: 8L, 3S1P/4500, CC120, x637 (49mph) -- M-1 SuperCat: 1521/1Y, 6S2P, CC240, x447 (61mph) -- SV27 Mono: stock setup, 14-cell/4200, x642 (42mph) -- Micro Scat Cat: 28-3600, 3S1P/2100, Turnigy 60, x430 (41mph)
                  • Doug Smock
                    • 5264
                    Thanks,
                    I took some pics of the setup but they are dark. ( this guy paints the inside of his boats black) It is the same setup as the LSH except the ESC is turned side ways right in front of the motor, and there is no rec pack.
                    I'm bulding one for a fellow in Washington, I'll post pics of it.
                    Doug
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • Doug Smock
                      • 5264
                      Here are a couple I built for two of Phil's customers. Both of these are running SV 27 power systems and Fullers hardware.
                      Doug
                      MODEL BOAT RACER
                      IMPBA President
                      IMPBA 19887L CD
                      NAMBA 1169
                      • flyboy320
                        • Mar 2008
                        • 88
                        Those are sweet paint schemes Doug!!
                        I found the best cf prop for my setup (SV27 power as well) was a 42mm. The 45mm heated the motor up to much (about 160f), where as the 42mm keeps it cool at around 120f max (two 2S 5000mah lipos for power).
                        • Doug Smock
                          • 5264
                          Thanks and I'm glad you got yours dialed in.
                          The red and yellow boat is going out to a guy that runs for sport, so I think I'll dial his in with a x442 before I send it out.. I have also been tweeking on some others to play around with.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Doozie870
                            • 828
                            Looking and running great! Whats the purpose of having the servo so far offset?
                            • Doug Smock
                              • 5264
                              Thanks Doozie. There is a cut out in the stringer for the servo. You can move could move the servo out but I haven't had any trouble with the 1/16" SS wire.
                              Doug
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
