Thunder tiger outlaw jr. obl rebuild
  • joshsubmec
    • 11
    I dont have much of a detailed boat build but here it is..my thunder tiger was just to slow being stock so i went ahead and ordered parts for an upgrade...bad idea. The new setup im using is a 3650 watercooled
    inrunner with a 50 amp esc with octura x440 prop. 2 2s 2200mah batteries(i want to get 5000mah instead but had them layin around). I wan it in the little 12 foot wide canal i got by my house and got speeds around
    35-40 mph instead of the 25mph it used to do. Now for the old setup...It had a 1900 kv 29/by19?outrunner brushless motor with a 40 amp esc. I used a 3s 2200 mah battery with stock prop. Here are the pics of my
    new setup in my boat..TT boat.jpgtt boat inside.jpgThunder tiger.jpgtt boat and radio.jpg
  • gyrotron
    • 499
    Can you post some videos? I am thinking about modifying mine too.
    • joshsubmec
      • 11
      I will try and get some up this weekend if i remember too..im in school now so gotta wait till weekends.
      • Wtaylor3
        • May 2012
        • 13
        I look forward to seeing videos?...what do u guys think of the outlaw jr with This motor http://www.offshoreelectrics.com/pro...o-3674&cat=148 in 3270kv I'm pretty set on the motor as it was recommended to me by the members here I'm just not sure on the kv rating...I want to run 50mph+...I was thinking a seaking ESC in 180-200a and running dual 3s or even 4s packs.
          • 9481
          way too much kv, go for more of a 2200, and run 4s on it
          M445 prop and have fun!
          • Acer225
            • Aug 2012
            • 9
            What motor and ESC would y'all recommend for a boat like this
            • gyrotron
              • 499
              This is the setup recommended by Steven at OSE:
              "replace the mount with a ose-80230, This will take modifying the boat and mount.
              the motor with a leopard 3650 2290kv,
              the esc with a seaking 120
              the battery with a 3s 35c 5000mah pack. Use 5.5 bullets on the battery ends. and at least 4.mm bullets on the motor to esc. 5.5 would also be better there."
              I hope it helps.
