Originally posted by battlefury
View Post
Whiplash Sport 40 Build
I would love to see one of those in Brushless!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
I placed all hardware in boat, and moved everything around until i got CG close to turnfin. I decided not to remove front bulkhead because CG would have been too far forward. Especially after adding lead to front lefthand sponson.Attached FilesLast edited by detox; 08-16-2012, 07:55 AM.
You've got the motor further back than I do. I'll have to check where mine balances when I get home, if I remember correctly I'm about 1" behind the turn fin. According to Blazer the whip isn't too sensitive to COG placement. I didn't add any extra weight to the left sponson and I don't have any issues turning at full speed.
The ML Boatworks Whiplash 20 Cowl also fits the Whip 40. I heated cowl with blowdryer to get perfect flat fit.Attached Files
I have an Insane30 that hops in turns and I think the left sponson weight is the issue there. I'm going to add a little weight to see if I can calm it down some. But the 40 stays flat and flies through turns. Bad thing with the 40 is the only way to add weight after it's built is on top or side with stick on weights. Here's an idea, small fuel bag with a tube into the center section that you could put maybe sand or water in to add weight?????
The motor mount is what I am working on now. Motor angle is 13 degrees and plate is mounted 10 3/4" from back edge of sternAttached Files
IMO, i do not think any weight is needed to add on the sponsons. I dont recall the instructions sheet mentioned about adding weight or whatsoever. having said my whiplash is senstive to strut settings but forgiving to CG adjustments in relation to different props tested. As long as the strut settings to be about 0.75"-1" below the deck and not more than 2 degrees angle the boat will ripped the pond!
i like to run them loose btw. I think it will ease amp drawn for e electronics
Of course it will.Originally posted by battlefury View Posti like to run them loose btw. I think it will ease amp drawn for e electronics
Not much done. Using 1/32" plywood I sealed off rear compartment to keep electrics dry and better floatation. I am building this hull as lightweight as possible, but weight will be added to sponson...especially lefthand side.Attached FilesLast edited by detox; 08-29-2012, 05:42 PM.
I am using the Owens Corning 3/4" Pink foam board for floatation. I cut all pieces using utility knife then shaped using 80grit sandpaper.Last edited by detox; 08-31-2012, 04:21 PM.
For rough balance 2" behind rear sponsons I epoxied 5.7 ozs lead to lefthand sponson tip and 4.56 ozs lead to righthand sponson tip.Attached Files
