Delta Force 33
  • knpc
    • 649
    Heath,
    Thanks for the info, I got this one because it is what Steven has listed as recomended hardware for this hull. The next size up is 6.25'' . That would put 3.75'' of the rudder in the water. Is that too much? Right now I only have 1.5'' in the water.
    Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
    • z400
      • 1333
      I've currently got this rudder- http://www.offshoreelectrics.com/pro...=ros-21-rudder
      on a delta force 29 hull
      someone here recommened it
      and i was told it would be perfect
      its long yes.
      i'll be trimming it up some if needed after break in is complete
      Z
      KBB34" Mono - Fast
      ToySport Triton- Not as fast
      • Doug Smock
        • 5359
        I don't know Heath, I built one for a club member that will go where ever he points it. One difference is I cut 1" off of the stinger which puts the drive dog even with the leading edge of the rudder.
        The boat is powered with a 1515 1Y on 4s2p and a 640.
        It could be that if your running a big wheel that you'll need more rudder on that hull. IME If your rudder is 1" longer than the prop with it positioned straight up and down, you should be in good shape.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • Heath M
          • Mar 2008
          • 865
          Hi Doug
          i run that rudder on my 29 and it's brilliant, if not too good, i have to turn the trim right down so it doesn't hook..i also cut 25mm off the strut
          Both Paul Packmeyer and Steve Reesor have said to use the longer one on the 33.. guess i'll find out in a couple of weeks when mines done :)
          Brisbane,QLD, Aussie
          • knpc
            • 649
            I had been looking at that debating whether or not I should cut it down. Right now the drive dog is even with the trailing edge of the rudder. I could take off 3/4'' if that would improve the handling. I had the same length rudder on my 29'' titan with no handling issues but the leading edge was even with the drive dog.
            • Ocean Racer
              • 511
              Why dont you try making a plateform to push the rudder out a little bitt before you cut the strut up.
              Failure is the First step to SUCCESS
              • Doug Smock
                • 5359
                I understand Heith and would be one of the last to argue with Paul and Steve, I was just expressing what my experience has been with that hull and hardware combo. Good luck with your build.
                Again from what I have seen we are running small props on our P monos compared to most folks. There in probably lies the difference.
                knpc,
                I would run the boat as it is and go from there. You may be happy with what you have!
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • knpc
                  • 649
                  Thats a good idea to extend the rudder. It would be easier to make a piece of alum and longer steering linkage than it would be to cut the stinger and flex cable.
                  And your way is reversable. I will prob test it as is in a week or so when its done and go from there. This is great information to have when I do make adjustments.
                  • Heath M
                    • Mar 2008
                    • 865
                    Doug's right,
                    Run it as is and see how it goes,then decide if you need to make changes or not :)
                    I think you maybe able to buy a rudder bracket extension!!! I think Propperchopper on RR bought one, but don't quote me on this
                    Heath
                    • knpc
                      • 649
                      My Delta Force 33 is just about done, only needs some final adjustments on the hardware. I plan on running it this weekend and let you know how it goes. I may even be able to convince my wife to take some video.
                      Thanks for all the help
                      Kevin
                      • Doug Smock
                        • 5359
                        Good luck, er, ehh, break a keel !!!!
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • Heath M
                          • Mar 2008
                          • 865
                          Hey Kevin how did the boat run????
                          Heath
                          • knpc
                            • 649
                            I took it out for the first time earlier today but it was too windy to open it up. It did handle the chop good though. I hope to take it out later in the week and will post how it goes.
                            • Avanti
                              • 1298
                              any updates on this rig? what size strut and flex shaft are you running?
                              The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
                              • knpc
                                • 649
                                It has a 3/16 strut and a .150 flex cable. The ran boat good but I don't think the 9xl is enough motor for this hull. I plan to put a neu motor in soon. I've tried adjusting everything and can't get it dry. Hopefully a more powerful motor is what it needs to run dry and keep the temps down.
