Hydroplane cowling
  • podagee
    • 28
    Hydroplane cowling
    Has anyone made there own cowling for there hydro. I was wondering cause it just looks top heavy and I think a low intake would look good to.
  • JimClark
    • 5913
    Made several of them. What kind of hydro
    Billy Graham
    • Jesse J
      scale FE enthusiast
      • 7818
      Me too, I take a profile I like and then cut mIne out of construction foam then glass and epoxy. Done lots! See my avatar- that one is foam and glass.
      "Look good doin' it"
      See the fleet
      • podagee
        • 28
        Where did you get the construction foam. And the heat from the epoxy it don't melt the foam
        • podagee
          • 28
          Oh I'm making a 74" 1992 budweiser T4
          • jcald2000
            • 786
            Epoxy won't melt foam as long as you mix it properly, follow the mixing instructions exactly.
            Polyester resin WILL melt foam!!
            • Jesse J
              scale FE enthusiast
              • 7818
              I got my construction foam or insulation board at the local lumber yard. Granted that was in Montana, doubt they sell it in Houston.
              I went to the yard and asked the guys if there were any damaged sheets and ended up walking out with a 3x4' chunk under my arm for free!
              See the fleet
              • JimClark
                • 5913
                Home Depot should have the foam depends on what epoxy you use if it works or not it has to be the slow curing type.
                Sent from my MB611 using Tapatalk 2
                Billy Graham
                • podagee
                  • 28
                  I went to home depot and the foam they have is the one for your garage door, it comes in 4 x 8' sheets. But the foam is the white one, the one that has all the small foam balls heated together. I'm using the west system slow cure epoxy.
                  • JimClark
                    • 5913
                    What you want is either the pink or blue foam
                    Billy Graham
                    • podagee
                      • 28
                      I'll try and see if I can get some tomorrow
                        You want Styrofoam, a trademarked name product. When I lived in Alaska I could get the 2" thick Styrofoam at any building store, but in more temperate climates it is not available. All I can find locally is 1/2" thick 4'x8' sheets. I have glued these thin sheets together with epoxy to form thicker sheets. Keep the glue away from any edges you want to sand, it will make a scalloped surface.
                        A common question we hear all the time is, “What’s the difference between Expanded Polystyrene Foam and Styrofoam Brand Foam?” Some times, people are looking for expanded polystyrene foam products, but mistakenly refer to them as Styrofoam Brand Foam, even though the materials are completely different
                        • JimClark
                          • 5913
                          I got a piece in the plumbing it ts used to put under the waterheater. I have also made one out of balsa. How big of hydro?
                          Billy Graham
                          • podagee
                            • 28
                            Well I don't think they have it here in las Vegas. I tryed looking every where. I tryed the floral foam it works fine it's the green one.
                            • detox
                              • 2357
                              Custom car shops use 2 part expanding foam to make custom moldings and flares. After foam expands and cures it is sanded and shaped by hand to make the plug for mould. I seen this on Speed channel.
