41" Fantasm Build AKA "DARK MATTER"
  • boddenboys4
    • Jan 2012
    • 94
    Ok I'm finally getting to post my build. Its my first build so be nice!!
    Well here is what I started with:
    1 - 41" FG Fantasm hull from FCR
    2 - 110mm Stingers W/Shafts
    2 - 1717 Castle/Neu Motors
    2 - FCR 240 amp 8s ESCs
    4 - Large Water Outlets
    2 - Thru the hull water inlets
    1 - Antenna Mount
    2 - Large Motor Mounts
    1 - Scaled Rudder
    1 - Vertical Servo Mount
    1 - High Torque Servo
    1 - 2.5 mm CF Plate
    1 - 24" x 16" CK cloth (Black & Orange)
    1 - Epoxy Resin
    Then theres the other nick nacks
    Ok I decided to do away with the 2 large motor mounts and make my own along with the cradle for the rear of the motors from the 2.5mm CF plate.
  • boddenboys4
    • Jan 2012
    • 94
    Having trouble uploading more Pics! Well I have completed the inlay and installed the stingers, rudder, motor mounts, servo mount with some minor modifications to let it set lower, water inlets and outlets, antenna mount.
    I will try uploading more photos later. I also have videos but you will have to wait. Don't want to get ahead of the build. Like I did with the build itself, you will see later.
    My plan is to complete the build, do all my testing and tweaking then I paint it. I think this is a good idea! Let you know later on!
    • boddenboys4
      • Jan 2012
      • 94
      DSC_1233.jpgDSC_1234.jpgDSC_1241.jpg There's the mounts. Ok time for you to see everything in and out so far!
      Ok that's a few more.
      Then I got ahead of myself.
      • boddenboys4
        • Jan 2012
        • 94
        Thought this had went up: IMG-20120430-00051.jpg
        My youngest, he cant wait either!
        • boddenboys4
          • Jan 2012
          • 94
          First Run on 5s, Like I said, got a little excited:DSC_2239.jpgDSC_2333.jpgDSC_2317PS15.jpg
          Now here's where I got a little too excited:
          That was the first run on 8s, little too windy.
          • boddenboys4
            • Jan 2012
            • 94
            Well after that run this was the outcome, Guess build and test then paint was a good idea!!!
            Thats what happens when you don't reinforce the transom.
            So I added a CF plate and CK on the outside and inside of the transoms. Problem solved!!! So I'm down a counter rotating prop for now, waiting on my replacement.
            IMG-20120606-00118.jpg Plates for the inside. Didn't take pics of the outside ones sorry.
            Bet your waiting for the video! Don't worry, soon get there!
            • Rumdog
              • 6667
              Nice build!
              That looks like one gnarly wipe out. Sucks about the transom. Sound like you got her all fixed up though.
              • boddenboys4
                • Jan 2012
                • 94
                Ok, this is a week later. Enjoy!!!
                This run was on a pair of borrowed Octura X450-3 Blade, they hadn't been balanced or sharpened.
                Time for the video, the first is on 5s, the second is 8s.
                Uploading videos, give me a bit.
                • boddenboys4
                  • Jan 2012
                  • 94
                  It actually took it pretty good. I love the power it has. I cant decide on the paint scheme yet, but black and orange are the 2 main colours. Want a ripping/tearing look. Need an air brusher on Island!!!
                  • boddenboys4
                    • Jan 2012
                    • 94
                    Here is the video with her on 5s
                    • boddenboys4
                      • Jan 2012
                      • 94
                      Here is the video with her on 8s
                      • boddenboys4
                        • Jan 2012
                        • 94
                        Here's the GPS
                        It twisted the stingers in, gonna have to upgrade them.
                        • Rumdog
                          • 6667
                          I'd bet that the unbalanced props caused the stinger failure. NEVER use raw props!
                          • boddenboys4
                            • Jan 2012
                            • 94
                            I balanced the props but now I need the stingers.
                              • 9481
                              specially at those rpms!
