Ron's FE30 P-Ltd Sport Hydro with new Turbine Cowl
  • properchopper
    rcgoatbuild@snotmail.com
    • 7708
    The first FE 30 I've built with the new turbine cowl. Looks great and allows more leeway for inside layout.
    Rear hardware with servo-rod pass-through tube (large diameter tube allows free no-bind rod travel)
    Rounded rudder bottom (minimizes lift)
    nylon shear bolt for turnfin
  • properchopper
    • 7708
    Ron's FE30
    Polished stuffing tube (.250 for .187 flex - allows for bigger motor later on) with my secret ultra clean hull entry technique
    inside stuffing tube entry
    Tinned flexshaft end and polished the flex for minimum friction (right side polished for comparison)
    • properchopper
      • 7708
      Ron's FE30
      Setting in 3/32" birch ply motor bed (stiffens floor and keeps motor-to-shaft in perfect alignment) - West Systems G/Flex used exclusively for ultimate strength
      setting in motor with mount , servo mount, and speed control mount (which keeps SC off hull bottom & dry if some water sloshes in)
      speed control on mount
      • properchopper
        • 7708
        Ron's FE30
        A little dab of anti-seize on the collet threads allows even tightening torque (got this from Jay )
        Cooling water inlet squeezed in keeps cooling line away from prop (learned this from personal experience )
        • properchopper
          • 7708
          Ron's FE30
          Finding room for antenna mount and leaving room for tape was a challange ; had to narrow a flat on the antenna fastening nut to have it mate properly under deck; used an o-ring to seal. (Ron will trim length once Rx is installed)
          Interior layout ; clean, simple & easy to maintain
          Threw in a CF turbine intake sticker - to be applied with windshield after paint
          Shameless Self-Promotion : If you want a RtR FE30 built to exacting specs, contact me at : rcboatbuild@hotmail.com
          Best Regards,
          Tony
          • RCKong
            • Sep 2009
            • 1680
            I'm curios about your rudder placement. The rule of thumb as far as I know is not to put the fin and rudder on the same side on a hydro ?
              RCK, that "rule of thumb" is pretty old and no longer applies if the boat uses 'enough' turn fin. I find that with an angled or curved fin I get great cornering with the rudder to the right on three different sport hydros. One big advantage is the boat is much less sensitive to left rudder inputs and is less likely to spin out or flip if a left correction is needed - plenty of races are lost when a racer has to give it a bit of left to miss a buoy or dead boat. That alone is a big advantage in oval racing.
              • Doug Smock
                • 5359
                Psssst..............http://www.autozone.com/autozone/acc...requestid=1158
                They work great on the transom Tony!
                Doug
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                • detox
                  • 2357
                  Here is a cool antenna mount that Brian fabricated using 5/32" brass tubing epoxied to the inside of hull. The plastic antenna tubing is a slip fit inside 5/32" brass tubing. He used small diameter fuel line to grip and seal plastic tubing.
                  • ron1950
                    • 3082
                    hey tony looked what showed up today lol
                    • properchopper
                      • 7708
                      Doug
                      Thanks Doug, will do the next build that needs an antenna using one of those. Ron sent me his antenna to mount so I did what I could. Still ample taping room. Oh, btw, I use internal antennas in my boats so haven't neded to improvise there.
                      • ron1950
                        • 3082
                        hey doug how do u use those elbows etc for your antenna mounts any pics at all?
                        • RCKong
                          • Sep 2009
                          • 1680
                          Real nice boat Ron. Looking forward to seeing it run.
                          • ron1950
                            • 3082
                            thanks brian me too.....too darn hot here to even try it...100 today 104 later this week...my a/c unit is tired lol
                            • RCKong
                              • Sep 2009
                              • 1680
                              windy and rainy here... 56 mph gusts today
