Hpr 06 / 115 build
  • Chrisg81983
    • Jul 2011
    • 1556
    #241
    What do u need
      • 7651
      #242
      I fear my cables are just too wide and that the angles are not going to work.Maybe overthinking. Let me finish assembly here and I'll post a pic in my thread.
      • Chrisg81983
        • Jul 2011
        • 1556
        #243
        Ok let me know if you need more pics
          • 7651
          #244
          You have a much straighter shot than mine.Unless I make a major change(it isn't painted yet)
          • Chrisg81983
            • Jul 2011
            • 1556
            #245
            Yes its pretty straight the spread is 2.75 inches
            • ManuelW
              • Oct 2010
              • 743
              #246
              Hi Chris,
              great to see what you made out of the nice hull and all the parts. By the way are you satisfied with the Nokon PTFE liners for the hydraulics which I sent you?
              regards,
              Manuel
              • Chrisg81983
                • Jul 2011
                • 1556
                #247
                Thanks manuel and yes the ptfe liner is a perfect fit it seals the linkage cable so well I didnt even need to seal the end off. It wont leak a drop
                • dasboata
                  • Dec 2010
                  • 3152
                  #248
                  Chris sounds like you can go bigger on the props !
                  • Chrisg81983
                    • Jul 2011
                    • 1556
                    #249
                    Hey chris whats up man I need some magic from u......anyway I ran today n got 83.3 on 6s and 94.7 on 7s soon I will hit 100 I hope
                    • dasboata
                      • Dec 2010
                      • 3152
                      #250
                      I have the set of 457 sitting here I will do them up for you for next weekend !!!
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1837
                        #251
                        Chris, you may be safer to run a smaller 3 blade or more RPM?? to big a prop on that setup will surely get you
                        damn, your 2 mph faster than me LOL
                        • dasboata
                          • Dec 2010
                          • 3152
                          #252
                          The 57 will be cut down to 52 MM with some other work I think he will be fine !!! But then again I am a gas guy !!!
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #253
                            Yo Chris, I did spin the 57-52 with my 2250 @ low 30k worked great but a bit on the warm side of things. 2240's at high RPM, I don't know man? Those props have some bite. I run mine with a set of 2280's on a boat that's 20% bigger then what Chris is running now. I would stick to props in the 45-50 range. I think my 457-52 run even better than my 457. I get more speed with the 457's but also more heat.
                            • Chrisg81983
                              • Jul 2011
                              • 1556
                              #254
                              Yeah kent I did some proo testing yesterday and a 447 or a abc 1616 is about max on 7s but chris I will have u make the cut 57's for me when I build my hpr 135 witb a bigger motor like some 2280's or some 30xx's nedd to look into it some more
                              • Chrisg81983
                                • Jul 2011
                                • 1556
                                #255
                                Damn guys i am trying to get to lake but on a stupid 6 hr gas line due to the storm here in N.Y. / long island. Just hope by the time I get to pump there is still gas here lol.
