Df 33 build
  • Graeme
    • Jun 2010
    • 97
    Df 33 build
    I found a deal on a DF 33 with uninstalled hardware I couldn't pass up so here is my take on a DF 33. This is my first build so any advice appreciated.
    I already have a T180 so I decided to go with a leopard 4074 2000kv on 4s.
    Going to start with a 442 then 444 if that works out will try an x645
    Will be running 4s 10000mah. 4s 2p.
    Reinforced the hatch.
  • Graeme
    • Jun 2010
    • 97
    I was not overly happy with the options available for 40mm motor mounts so I decided to build my own rails.
    Transom all drilled out and ready for hardware.
    Hardware installed
    • Graeme
      • Jun 2010
      • 97
      I am still waiting for my batteries once I have received them I will be able to set the COG and install the battery tray appropriately.
      • Graeme
        • Jun 2010
        • 97
        Next step while waiting for the batteries will be to figure out how to mount the servo and esc.
        • Graeme
          • Jun 2010
          • 97
          Comments suggestions ?
            • 9481
            I like it!
            • Jesse J
              scale FE enthusiast
              • 7818
              beautiful graphics!!! I LOVE it!!!
              not enough motor. I recommend the Neu 1521 1.5D... just ask lipopower!!
              The leo will get hot and not give the speeds a Neu will give. Plus it will wear out much faster than you will like...
              that said, what are your goals?
              "Look good doin' it"
              See the fleet
              • Graeme
                • Jun 2010
                • 97
                I am sorta regretting not buying a leo 4083.
                I was hoping to get it running around 50+ mph but I think with the 4074 that 40-45mph would be a more realistic goal. Maybe I should just scrap the leo's and go for a neu.
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  I suspected you wanted to tap the potential of this hull...
                  And the neu will do just that! Overheating a motor can take out the rest of your electronics which can quickly justify the price of the neu.
                  See the fleet
                  • Rumdog
                    • 6667
                    You certainly don't NEED a Neu. Just sell the 4074 and get a 4082.
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      I got low 50s with a fiegao 9xl on 4s in a DF cyberstorm (short 2-3 min runs) would think a leo 4074 would be a decent step up from a 2 pole 3674 motor.
                      but if you have the cash for a Neu it would be a much better choice
                      • Graeme
                        • Jun 2010
                        • 97
                        My main goal with this set up is to have a reliable setup that won't go up in smoke.
                        For the most part I will be using the full 10000mah 4s capacity until I hit LVC.
                        I want it to go fast but I am certainly not looking to push my gear to the breaking point.
                        From what I gather the 4074 will work but I would be pushing the limits of what the motor can handle.
                        I think I am going to order up a 4082 and try to stuff the 4074 into my apparition.
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          Unfortunately the old adage applies greatly to FE, "Fast,cheap,reliable pick any two"
                          But we do get better speed, reliability at a much cheaper price than a few years back before brushless and lipo.
                            • 9481
                            Also the 4092 would help again
                            That's what I have in mine and I hope to try out my DF33 this weekend
                            not sure what prop to start with... M447
                            • Jesse J
                              scale FE enthusiast
                              • 7818
                              I have the 4092 in my 34" balsa cat and it is in the low 40s and the motor gets warm 130 after two laps... and closer to 150 after 5 laps, on a mild prop. Granted she is not as loose as I am hoping to get her, but that is my experience.
                              See the fleet
