Electra (tenshock 95)
  • Remmie81
    • Apr 2012
    • 134
    Ray,
    Longer drives/struts will minimize blowovers and having the rudder behind the props is giving better steering.
    Grtz,
    Remmie
    • xkos
      • 192
      fist trim....
      Tenshock Electra Twin
      Vortex Hydro 24'
      • xkos
        • 192
        i decide to replace my tenshock viper 2250 2600kv (2500watt) motors with TPs...
        4050L 2350kv (3600watt) on 5s and sometimes on 6s
        i look forward to try TPs...
        Vortex Hydro 24'
        • grsboats
          • 1011
          Very sexy for sure and will be a monster with TP motors.Thanks for sharing Gill
          GO FAST AND TURN RIGHT !
          www.grsboats.com.br
          • xkos
            • 192
            Thank you Gill,
            i have seen many hpr with the same setup, 70-80mph is the goal. Hope for a good result.
            Vortex Hydro 24'
              I see TP is putting bearing on outside of front plate now, interesting... Easier for bearing replacement...
              • ozzie-crawl
                • Sep 2008
                • 2943
                I ran mine on sunday (same hull) with 2 leopard 3674s (1700kv) on 5s with 442s. First test run i did 4 passes just to test and each pass hit between 63 and 64mph.
                This is a sport boat setup so I am sure yours will have no trouble getting 70-80mph.
                • Cooper
                  • Jan 2011
                  • 1168
                  Nice lookin boat, I have several 40xx tp motors, all good only problem I ever had was wrap on rotor let loose. But I believe that was from stressing the motor past its operational limits. Kept them under 40k and have never had issues.
                    Sorry to hi-jack but, Pete, if you were to try one in a 36" whip for Q-hydro, which would you pick?? I can't afford a Neu...
                    • Cooper
                      • Jan 2011
                      • 1168
                      Cooper= R.W. Ford,,, lol,,, http://mbp-rc.de/TP4050L-5D-2350kv-3600Watt_1 maybe? 4s? I'm not as knowledgeable on them. It's a 4082 they measure by rotor not can.
                        • 9481
                        What about
                          Yeah, I was thinking that too. I emailed them because they show a 1215Kv 4060 for sale but, it's not on the charts...
                          Cooper= R.W. Ford,
                          Sorry, I keep thinking your first name is Pete, Peter.... brain fart from the MI Cup...
                          6S Whip- Q-Sport... build for winter...
                          • Cooper
                            • Jan 2011
                            • 1168
                            6s but figure out what combination of battery fits, might not get a single 6s 5amp in some of the sponsons.
                            • jkr
                              FE Addiction
                              • 582
                              Thats a great power-looking cat!
                              Ray you can also try a Typhoon from highendrc......
                              • xkos
                                • 192
                                I emailed them because i had some questions about kv and watt. Here is the answer...
                                Dear Kostas
                                Your TP4050L is 2350kv .we special make it.and also we can make 2450KV ,but all KV will be up and down at 3%
                                Accturlly the Max Power is over 4200W .
                                The 3800W on the website is data we just show in website.
                                TP4050L Brushless motor is an update one for TP4050 in 2012 .
                                From 2013 Augest , TP will update the motor can as one set.
                                the outlooking size will be changed from 40*82mm to 39.5*76mm
                                Just for the records...order was made directly from the factory (Hong Kong)...great deal and fast shipping to Greece!
                                Vortex Hydro 24'
