MHZ Mystic 1380mm build
  • MrUnlimited
    • Jan 2011
    • 94
    #571
    Very nice paintscheme. Are they vinyl decals? I started a blog about the progress of the "buildproces". You can see it at: www.v10power.ws
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      #572
      Yep, all 900 series Avery metallic vinyl, but a solid 2pac silver base. Should have her done by the weekend if I get the hull back from the painters.
      • drwayne
        • 2977
        #573
        Originally posted by MrUnlimited View Post
        Wayne, Hifei has indeed no relationships to Sktrc but in my opinon it is free to use the name swordfish for an esc by any company unless it is registrated name. Skyrc has already an esc called Swordfish: http://www.skyrc.com/index.php?route...product_id=111
        Burn and learn....
        • RaceMechaniX
          • 2825
          #574
          I thought the AS 26.150BL's were limited to 6S? Were you running these controllers for 8S?
          TG
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1837
            #575
            TG
            no no, 8s is the limit (hence the "26"), same as the AS26.200 both models are AWSOME! and you can pull some sick amps compared to what the lable states. Also very small unit that fit anywhere.
            • RaceMechaniX
              • 2825
              #576
              That's kind of what I assume, but those are some pretty narrow voltage margins then. I got mixed up on some of the nomenclature. MGM goes by voltage input where as Schulze and Model Regler go by number of NiMH cells. I was just looking at a 28026 and thinking to myself I know that's a 6S controller.
              TG
              Tyler Garrard
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                #577
                Good question what they've done? I think the limit is 35v?, but seem to work great with no problems. Wish I had the AS26.200's as they should be good for a burst of 300-400A. I have to say, if the goal is no more than 8s and you don't want to break the bank, this is the one. I should be able to break the 100mph mark in my 54" with the AS.26.150's so they got plenty of GO!
                • arrowskartax9
                  • 130
                  #578
                  Hi Kent, Can you make Herring Propeller and Mystic decals like these in scale for my MHZ Mystic 114 Aquamaniamystic_powerboats_logo_900.jpgHeringPropsLogo.jpg
                  Would these be the correct size as they are?
                  Thanks,
                  Chris.
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    #579
                    Sure I can
                    • arrowskartax9
                      • 130
                      #580
                      Great, I would like 6 of each one.
                      • Xcesive8
                        • Jul 2009
                        • 395
                        #581
                        This looks really really good!
                        Cant wait to see how it looks in the flesh..
                        Ryan
                        Originally posted by nata2run View Post
                        Hello, now that she is at the painters ive been working a abit on the new design. Someone has to be the first right? I always like simple layouts so I'm trying this one soon as I get her back.
                        [ATTACH=CONFIG]86367[/ATTACH]
                        • Alfa Spirit
                          • 2131
                          #582
                          Here is the logo
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1837
                            #583
                            Thanks guys for the comments and artwork also ......
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #584
                              Hello Folks,
                              Got her back from the painters on Friday, and had a play with some artwork....
                              also took her out today after rebuild and testing the new 5mm flex drives and couplers. Seem to work great'
                              • arrowskartax9
                                • 130
                                #585
                                Looks Great. I really like the colour scheme. Cant wait to see it on the water.
